![]() | Home > Technical > Td5 brake flexi |
Does anyone know if shb500230 flexi hoses fit a td5 110 ? Or if not does anyone know the correct part number for front flexi hoses for a 2004 td5 110 csw?
Cheers Ray Ray My build thread http://www.defender2.net/forum/topic17615.html |
I wasnt sure if it would be worth putting braided lines on for a standard braking system. The original flexis are fine at 14 years old but I got an advisory for the front brake pipes so thought I'd buy new flexis just to make the job easier. Ray
yes 04 and onwards front flexi hoses pipe changed too this type |
Hmmmm, mine is a 2004 on a 53 plate Ray
![]() Click image to enlarge 04 and onwards front flexi hoses pipe held in place with metal clip at both ends or NRC 7874 on up to 04 ![]() |
That's perfect thanks
![]() My build thread http://www.defender2.net/forum/topic17615.html |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5889 ![]() ![]() ![]() |
I like my braided hoses from Llama 4x4
![]() Regards John M0VAZ Econet Station 48 no clock |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
^^^^ I've already suggested them, I know how good they are too
I'll check them out
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1679 ![]() ![]() ![]() |
Check if it’s a nut or a clip that holds it on at the spring hanger, that’s the difference in the two hoses
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 601 ![]() ![]() ![]() |
Just a word of warning, my original flexi hose after 16 years started leaking brake fluid due to corrosion... only 2 days after it passed the MOT.
The corrosion wasn't apparent until after it was taken off and MOT inspectors aren't allowed to pull the car apart to find issues. |
i had 5 year old braided hoses fail in MOT brake test
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2957 ![]() ![]() |
I think I saw on here the ones that do away with the swivel clip bolt
