Home > Puma (Tdci) > no drive at all - output shaft dies @ 65 000 km
Page 1 of 3 123>
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi there, my output shaft died in the middle of nowhere (Swiss mountains) i.e. total loss of drive ... Neutral
Now I have to decide :
- order brand new original parts from Land Rover - or
- order the optimized kit from Ascroft (http://www.ashcroft-transmissions.co.uk/mt82-output-shaft-kit.html)
From my point of view the dry connection is faulty design ( = crevice corrosion not taken into account)
Corrosion is only a matter of time what's going to end in the failure of the connection (= loss of drive).
Now I'm quite frustrated since I do not know how to avoid that stupid freshman design mistake.
We've been in the Sahara twice. In my opinion any shaft failure in the Sahara means loss of the car (or most of its parts at least Neutral )
Did Land Rover possibly modify their original parts for some reason? Better materials?
The dealer claimed that Land Rover wants him to lubricate the connection with some grease. Does it help?
Did anybody ever hear that an Ashcroft kit failed ?
Any answer / solution is mostly appreciated ...
(it's a 110 MY2012)
Post #706448 10th May 2018 3:27pm
mick
Speaking to the lads at Stonelake the other day about a rear diff for mine they said Ashcroft every time same as with the Outputshaft which I have fitted and they have done a few now with no failures.
Post #706454 10th May 2018 4:53pm
LR90XS2011
there are several threads on here about this issue and no one has reported an Ashcroft failure yet, for an overlander the Ashcroft kit should be considered an insurance policy against the inevitable standard shafts ultimate demise DEFENDER 90 TDCI XS,
Post #706461 10th May 2018 5:51pm
UtilityTruck
The thing that makes me uneasy about the Ashcroft mod, is it’s effectively a controlled gearbox oil leak- two problems with that, could it leak enough to affect the fluid level? Second could contaminates from the output shaft, e.g. metal particles make their way back into the gearbox?
Perhaps I’ve misunderstood and certainly I’ve not heard of problems with the Ashcroft mod, but their concept makes me uneasy.
What’s stopping someone modifying the shaft housing to include a grease nipple? 2014 Keswick Utility 2.2
Post #706465 10th May 2018 6:07pm
Caterham
/\ already done.
I think SeriesIan (think that's him on here Embarassed )
seemed like an excellent solution?
Post #706466 10th May 2018 6:10pm
LR90XS2011
yes several have done a home made grease nipple mod and as Caterham states Ian Series one has done it DEFENDER 90 TDCI XS,
Post #706467 10th May 2018 6:14pm
Julie
I suppose that the connection is inside a housing that these guys have to unmount before they are able to change the shaft.
The grease nipple is somehow uncomfy to reach, isn't it?
Although the grease nipple is the best solution. In both my Citroën 2CV was the same connection with a grease nipple.
My Land Rover is now in garage for harvest machines. These guys were laughing at me when they saw the connection without the nipple saying: "in each and every harvest machine these connections have a grease nipple." These experienced guys all knew that too much wear occurs without renewing the grease. But without grease ?? That's awful.
Well, Land Rover, shame on that ... Embarassed
Post #706469 10th May 2018 6:15pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Here you go. Thumbs Up
I put a grease nipple in mine a few years ago, drilled and tapped the outer case to accept a gear box level bung,
Which is a good size to get the grease gun through.
It gets a few pumps when I do the UJs, not had any issues so far?
I do a fair amount of towing, and covered well over 40,000 miles.
I work on a lot of plant equipment, and as said above anything that’s got a pivot, bearing, splined joint etc needs to be greased, not sure what JLR were thinking at the time?? Rolling Eyes
I’ve replaced a few of these now, some wear really badly, others hardly have a mark on them?
Anyway, Cheap experimental fix and it seems to have worked for me. Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #706481 10th May 2018 7:12pm
UtilityTruck
Nice one. Now you posted the pic I think I remember seeing it before. So, this is a transfer box off job? Did you do it originally because of a failure, or as a precaution? 2014 Keswick Utility 2.2
Post #706486 10th May 2018 7:28pm
Julie
Ashcroft modifies the original Land Rover parts. After installing the lubricated parts the mod cannot be worse than the original parts Whistle
Metal particles are also inside the gearbox. An oil change may help ...
The grease nipple is not the problem - but what about the old grease inside the housing.
The housing has to be removed in order to sort the old grease.
@Ian Series: The nipple is not the problem. The guys at the garage will install it within a few minutes. But what about the accessibility and the maintenance? A picture after installation would be helpful. But its hidden inside the housing and one cannot see what happens while shooting with the grease gun ... That's not too clever, is it?
Post #706488 10th May 2018 7:30pm
UtilityTruck
Julie- there is no grease nipple in the original install. it appears how well greased the output shaft is when it was originally installed at build has some bearing on how long it all lasts before failing. 2014 Keswick Utility 2.2
Post #706489 10th May 2018 7:32pm
Julie
Utility Truck, the nipple is a DIY mod - I know. Although lubrication is essentiel.
It appears that there's no grease in a connection after it failed.
Land Rover have the dealers lubricate the connection while installing the replacement.
From what I read in the web the connection may fail if lubricated or not ... Confused
Lubricated or not - after its failure you're going to find only the rust and no grease. Crying or Very sad
And what happens inside the housing? Nobody knows ...
With or without nipple - we have to remove the housing and check if the grease gun was successful or not - i.e. a EUR 1000 / GBP 800 maintenance every 3 years Shocked
Post #706492 10th May 2018 7:53pm
NickMc
I would go for the Ashcroft solution if you want zero maintenance. I’m sure it is well thought out product, t the end of the day they’re Land Rover gearbox specialist so I’m sure they’ve seen a lot of failures to come up with a solution that works. Their after sales service is second to none, the advice is always free and I’ve had Dave contact me after hours because “I didn’t want to leave you waiting” cant ask for more than that in my eyes Bow down
Post #706494 10th May 2018 8:04pm
ian series 1
I did mine due to a clutch rattle, my shaft was still good at 85k with very little wear,
It was more of a precaution, as I had already done one at work which had failed.
Personally I find them a faff to do with the box in situ, they are so much easier to do on the bench! I drop the box and transfer box in one, I tend to replace the clutch while I’m there. Thumbs Up
Julie,
There isn’t much to see other than a oil plug at the bottom of the adaptor shaft casing!
Undo the bung, turn the prop until you can see the grease nipple through the hole, I use a fixed head grease gun which is easier to get on the nipple, rather than a flexible one.
I can’t see excess grease being an issue?
It may also look like the grease only gets around one side with one nipple,
This is not the case, it finds its way around the whole circumference,
Post #706495 10th May 2018 8:12pm
Julie
The grease is going to find its way. After some miles the gear box becomes so warm what makes the grease very fluid.
Maintenance with a grease gun:
Under normal conditions one has to check if the old grease came out / stop if the new grease comes.
Also keep the outside dry and clean in order to prevent dirt creeping into the connection.
Surprisingly, the MT82 shaft is not the first "dry shaft" in the history of the defender.
Land Rover made the same mistake with the LT77 / Defender TDI 200:
And Land Rover found out how to protect the shaft from wearing.
They developed parts with holes allowing the gearbox oil to sink in ...
Now Ashcroft follows the same strategy !
Post #706501 10th May 2018 8:40pm
Page 1 of 3 123>
