Home > Maintenance & Modifications > Front dampers - which way up?
hank
I fitted Fox dampers to the rear of my 110 last year... They have a vertical pin one end and a horizontal bush the other as shown in the picture below meaning they only fit one way round; with the damper body up and the shaft down
Just fitting the fronts which have vertical pins both ends as per picture below, so which way should they go?
Standard ones are damper body down, shaft up however the standards have a dust cover!
The Fox don't have dust covers so if I fit them in the standard orientation there will be a mud trap on top of the damper body. I know there's a dust seal but I don't want to encourage muck ingress...
If I fit them damper body up, shaft down then the nice shiny Fox damper body will be hidden in the turret Laughing
Any suggestions?
Post #704641 1st May 2018 8:06pm
Devon-Rover
Sadly AFAIK both go body up. maybe buy so tubular or D44 turrets to see them. Whistle Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #704644 1st May 2018 8:11pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Here's mine Thumbs Up
Post #704647 1st May 2018 8:17pm
jst
Body up. My puma has them that way up to. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #704649 1st May 2018 8:20pm
hank
Thanks all. Body up it is... Gwyn Lewis HD Turrets ordered Thumbs Up
#tart
Post #704657 1st May 2018 8:34pm
UtilityTruck
How do people find the ride and handling characteristics of the Fox dampers? Also, what can you compare them with? I.e. what else have you tried?
OP- as others have said; body up to help the seals live longer 🤓 2014 Keswick Utility 2.2
Post #704663 1st May 2018 8:49pm
hank
I wrote a few lines on mine in the first response to this thread http://www.defender2.net/forum/topic57966.html?highlight=fox
I have nothing to benchmark them against other than knackered OE dampers but I'm very pleased with mine
Post #704767 2nd May 2018 12:54pm
MK
A monotube damper can be fitted either way. Anyway, it is better to keep the body shock away from stones and debris. Puma 110" SW
Post #704965 3rd May 2018 9:19am
