![]() | Home > Maintenance & Modifications > Advice Please - Door Hinges & Rear Door Strut |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2347 ![]() ![]() ![]() |
I wouldn't let this incident put you off purchasing a gas strut per se, as the benefits are significant. It also depends how often you use the rear door (which may seem like a strange thing to say ![]() I'd just keep an eye on things and keep things well maintained. Better still, have a look at what others have done to reduce or remove the risk e.g. Eric. ![]() As said earlier, I have the v3 on the original door and hinges with the spare mounted directly. No issues. I do now realise what I've gone and done... ![]() |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
I do not think I have to declare an interest here.
![]() Have no idea how many rear door gas struts we have sold but it must be thousands and that is from version 1 through to version 3. Now we have them fitted to our own vehicles and we have heard all sorts of comments. We have been told that the Version 2 rear door strut will never ever fit a Defender. That was apparently from a helicopter engineer! Ooops over 10,000 of these have been made. Personally I would not want to fly in a helicopter if that engineer had serviced if he could not fit a rear door strut! Do these struts put any excess strain on the door hinges? In my opinion the answer would be no. Other people might not agree. The door hinges are a pivot point for a lever/fulcrum. Now OK how to explain this. IF we consider the door handle to be about 1 metre from hinge point and requires a force of X newtons to open the door looking at 1 xX Nm Now if rear door strut was attached 1/10m away from hinge it would require 10X newtons to open the door. Personally I can not see a rear door strut having enough force to shear the pins in the door hinges. I do not know the force required to shear 3 pins of what about 6 mm diameter? The strut is rated at about 400-450 N. If the hinges pins do shear I would suggest that the hinge pins are in a sorry state to start with. Without knowing the diameter of the pin and something like the tensile or shear strength of the pin I would struggle to work out the force required to shear the pins. Brendan |
moresauce Member Since: 18 Feb 2012 Location: UK Posts: 50 ![]() ![]() |
Thanks again to all,
I'm ordering the strut and I tend to agree with Brendan's explanation. |
