![]() | Home > Td5 > Indicators not working with alarm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3355 ![]() ![]() ![]() |
Try changing the battery in your fob.
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 968 ![]() ![]() ![]() |
Agreed that is a good start, however are you sure the alarm is active? Check the red dash light. Perhaps it is just activating the locks and not the alarm / immobilizer... good luck. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Sancho Member Since: 28 Mar 2017 Location: Winchester Posts: 24 ![]() ![]() ![]() |
Agree with @Zed, it was the battery getting low in the key fob for me.
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Controlled by the 10AS suggest you get a wiring diagram.
Check the fuses related to the hazard switch. I had exactly the same only a few days ago when I inadvertently shorted out the indicators. Fixed them but no hazards or three flash when setting alarm. Eventually traced to one of two fuses marked hazards. Mine's a Puma so the fuse box layout is different but the basic system is the same. Darren
adeparko Member Since: 13 Feb 2015 Location: West Lothian Posts: 41 ![]() ![]() ![]() |
Picking this back up as I have bit a spare time next week So I don't have the flashing red light on my dash. Does this mean the alarm is activating and that's why no indicators? |
fuse 6 15 amp in fuse box under drivers seat box this fuse feeds alarm hazard input
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 645 ![]() ![]() ![]() |
Look into user manual, what does it means remote lock without indicators. Possible indication of some "open" door. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
It was the fuse that had blown ![]() Thanks again for all the help ![]() |
