Home > My Defender > An Anoraks Tdi Defender 90 |
It covers the opening in the bottom of the battery box where the bolt hooks in. Darren
23rd Apr 2018 5:16pm |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527 |
I might go check my pockets.......... 1993 200Tdi Defender 90
23rd Apr 2018 5:27pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5173 |
I will have to see if I still have mine Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
23rd Apr 2018 5:28pm |
shayes Member Since: 29 May 2016 Location: Devon Posts: 153 |
Darren,
Where did you get the 'pocket' from. Manufactured it yourself or a bought item. Recently replaced my battery on my 300tdi and can't remember seeing this item. Cheers, Simon PS- loving your new Utility. |
24th Apr 2018 7:15am |
I adapted an alloy project box, which was my very last purchase from Maplins Darren
24th Apr 2018 7:30am |
Ok, thanks for that. Went out and had a look underneath. There are two small covers over the slats, that the hooks go into (looking from underneath) so at least I know nothing has fallen off!!. Cheers, Simon
24th Apr 2018 8:49am |
karlp606 Member Since: 19 Aug 2021 Location: Hull Posts: 298 |
Ive got the same snorkel as yourself - mine is badly rusting on the top mushrow piece, is that just fixed on by the top bolts (highest up the windscreen)? |
19th Aug 2021 10:03am |
The mushroom top is held on by a large jubilee clip or clamp to the top of the tube. The windscreen bolts secure the tube itself. Darren
19th Aug 2021 10:38am |
I cant see any clips on mine where the mushroom bit is there is a very tight thick rubber band possibly a seal then only some plastic teeth like jubilee clip :/ and then just the bolts that bolt onto body near the windscreen.
19th Aug 2021 12:05pm |
The thing with the plastic teeth is the clamp Release that and the mushroom top will be free to lift off. Darren
19th Aug 2021 12:13pm |
Thanks matey, I guess you just slide them outwards to remove them.
Thanks again and your thread is like a running Haynes Manual! I love all the tinkering bits, taking bits off respraying etc - in fact where did you get your paint tins from? Did you do the hinges etc just from rattle cans? |
19th Aug 2021 1:02pm |
Yeah, from memory they slide sideways to release.
The paint came from The Paint Man for the coach enamel and eBay for the rattle cans. Yes, the hinges were just done with rattle cans - rubbed down and etch primed before regular primer and top coats. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
19th Aug 2021 10:03pm |
Mark0 Member Since: 12 Oct 2024 Location: Austin, TX Posts: 4 |
After a bit of a lead time all of my clutch parts have arrived 🥳
Click image to enlarge Also finished painting the inside of the wings and the wheel arches this week Click image to enlarge Hopefully I'll have the frame power washed out later today. Next up is to clean and paint the frame, engine compartment components, and engine side of the pillar. |
7th Nov 2024 7:16pm |
