Home > Puma (Tdci) > Water in footwell
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
Water in footwell
I have mentioned this before but I am not sure where it is coming from. Since I have bought the LR rubber mats I always find water on the front rubber mats on both sides. It quite a bit too but I can't figure where it's coming from. It seems to be dripping from around the pedal box. I get this when it rains hard or when the car is washed. Is this a known problem or is it definetily the window seal that needs fixing? 110 Black Java Puma Utility, Kenlowe fan, bullbar, sides step, tinted windows, bluetoth, Scanguage, BAS,
Post #70222 9th May 2011 8:04am
bob neville
110
Have a look at this thread - it may help.
http://www.defender2.net/forum/topic6077.h...water+leak
Bob
Post #70225 9th May 2011 8:30am
Grockle
110, windscreen seal but more likley from the door seals which can leak at the top front corner adjustment can help or new door seals will be needed. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #70234 9th May 2011 9:55am
Could be from behind the door card...
Or, what I did at the weekend, left my vents open and it howled down through the night Embarassed
Post #70236 9th May 2011 10:20am
gtveloce65
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Epsom Green
Mine was from the screen joiners - the seal had gone and water was seeping in through through the bolts and down behind the dash into the foot-well - cured with new seals 1953 80
1965 Alfa Romeo GT Veloce Sprint
1980 Fiat 124 Spider
2008 110xs
Post #70404 10th May 2011 12:29pm
