Home > In Car Electronics > Active Sub Wiring
buckers19
1993 Defender 90 300 Tdi CSW Barolo Black
Active Sub Wiring
I’m doing my best to install a Phoenix Gold active sub into my defender but have come a little unstuck due to the lack of a remote switch on terminal on the back of my head unit.
First question is where can I get a feed for this and second question is do I actually need it? The sub isn’t turning on without one so I would say it does but if anyone knows any different let me know.
The model of the sub is the Phoenix Gold Z8150
Thanks, Matt
Post #702133 21st Apr 2018 8:16am
mk1collector
You can use the electric ariel wire if there is one Ray
My build thread
Post #702139 21st Apr 2018 10:52am
An ignition live will do too, only your amp will be on all the time that the ignition is unless you have a manual switch. I’d try as above first.
Also some Amp’s have selectable turn on features / auto detect. See if that is a feature also KEEP CALM AND Drill ON
Post #702141 21st Apr 2018 12:02pm
