![]() | Home > Technical > Radio/Clock Fuse keeps blowing |
Loz2286 Member Since: 31 Aug 2015 Location: High Wycombe Posts: 121 ![]() ![]() |
My radio/clock fuse under the seat keeps blowing. Any thoughts?
Thanks guys. 1999 Td5 110 1999 Td5 110 CSW 1961 Series 2 88 LPG |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
I expect the back of the radio has got water in it. Either from a leaking screen or just from the bulk head vents.
Leave the plug out of the back of the radio and replace your fuse and if it doesn't blow you know it's the radio, if it does blow it's probably the clock. Ray
I think that fuse does the interior light too?
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 601 ![]() ![]() ![]() |
Yes it does, the wire between my front and rear interior light shorted which caused my radio fuse to blow.
That could be it. It first happened after I tried to change the bulb. 1999 Td5 110 CSW 1961 Series 2 88 LPG |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 672 ![]() ![]() ![]() |
In that case check you haven't bent a terminal in the interior light fitting so it is shorting.
