![]() | Home > Puma (Tdci) > Clutch Differences 2013 vs 2016 |
SkyFallSilver Member Since: 06 Apr 2013 Location: Kuwait Posts: 464 ![]() ![]() |
Hello,
My daily driver 2013 Defender has 83,000 km. I recently serviced it by doing engine oil, front, ear axle oil and transfer box oil. I will be going through the clutch as the rattle is rather annoying and it is time to replace it, comparing it to my 2016 Defender Adventure the clutch bite is different and the force is much heavier. Is there a new OEM part for a clutch kit that improves the experience, or should I go aftermarket ? In addition the manifold needs to be checked again and install a new gasket as the air leak has gotten worse. 2016 Defender 90 Adventure Edition |
Do you have the breakdown of the parts that I need to order ? 2016 Defender 90 Adventure Edition
86,000 KM on the original faulty clutch it rattles and it is getting more annoying and heavy to push down.
I have recently ordered a new clutch and clutch slave cylinder to install. ![]() Click image to enlarge Also replacing the gearbox oil with Motul 300 and installed a Nakatanenga turbo exhaust gasket which now performs better. 2016 Defender 90 Adventure Edition |
