![]() | Home > Maintenance & Modifications > Rear tub corrosion advice |
I'd cut the hole back to good metal to stop the corrosion travelling, treat the bare edges with something like por 15 then as you say bond and maybe rivet a new piece of Ali over the top then seal and underseal from underneath. Ray
ssg Member Since: 01 Mar 2018 Location: North East Posts: 65 ![]() ![]() |
I had the same problem a few years back, ended up riveting some of the front bulkhead ali I had just removed over the hole after clearing up the corroded metal and sealing it in with mastic.
Scott_Landy Member Since: 24 Aug 2015 Location: Cheshire Posts: 85 ![]() ![]() ![]() |
Thanks for that guys. Time to order some Ali!
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
They sell small sheets of ally in most DIY shops.
Being ally you won't need POR15, just rub it down to bright metal and repaint it with a bit of etch primer. Don't use silicone sealant, use proper body sealer - it doesn't affect paint and sticks better. |
