Home > Maintenance & Modifications > Fixing Dixon and Bate adjustable tow bar to rear step
MudHugger
United Kingdom 2015 Defender 90 Puma 2.2 Landmark LE Santorini Black
Hi
A bit of advice here please.
I have a Landrover rear step fitted to my 90.
I’ve bought a Dixon bate adjustable hitch on eBay to fit on it.
It came with 4 fixing bolts, however only one set of 2 holes line up. Each set
of two holes are 45mm vertically apart and the holes on my step are 55mm apart.
Do I
1) fix it with just two bolts? I’m guessing this won’t be secure enough?
2) drill additional two holes, so I can fix it with 4 bolts
3) return it
Thanks
Post #700148 11th Apr 2018 8:00am
jrule
United Kingdom 2000 Defender 90 Td5 CSW Oslo Blue
I think your best bet is to return as modifying to fit will not meet the relevant approvals and could compromise your insurance. There are swan neck type tow balls people on here have fitted to lower the height. If you want adjustable it’s probably best to remove the step and fit a Land Rover Dixon bate kit which is tested and type approved for this scenario
Post #700150 11th Apr 2018 8:25am
VVS210
My Dixon Bate adjustable set up has 6 fixings - the top 2 bolts go into the cross member; the next pair down bolt to an angle bracket that is bolted to the underside of the cross member; and, the bottom pair bolt to a plate that has the two rear brace bars bolted back to the chassis. I don't think the NAS rear step will accept this type of fitting.
Post #700174 11th Apr 2018 11:46am
gilarion
Sorry, but what you wish to achieve with an adjustable drop plate on your rear step cannot be done. As others have said either remove the step and fit the Dixon Bate set up. Or keep the step. Sadly you cannot have both fitted. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #700177 11th Apr 2018 12:13pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Re: Fixing Dixon and Bate adjustable tow bar to rear step
MudHugger wrote:
Hi
Do I
3) return it
Thanks
*If* I've understood your question correctly, I think you need the 150mm adjustable that has slots instead of just round holes?
https://dixon-bate.co.uk/products/gb/heigh...coup-.html
There are one or two threads on here with photos etc of people having that setup with the NAS step.
Post #700194 11th Apr 2018 2:01pm
VVS210
That model still requires the braces back to the chassis, if these are not fitted then any load on the tow ball will create a twisting moment into the NAS step - which is good!
Post #700272 11th Apr 2018 7:45pm
DAZ110
Have alook here:
http://www.defender2.net/forum/topic12818.html
Look at my 9th post down, I fitted this back plate to my tow step. Thumbs Up
Post #700281 11th Apr 2018 8:33pm
DAZ110
Or could try this tow step:
http://www.ppcages.com/?page_id=243
Or this tow step and get a drop plate:
http://www.extreme4x4.co.uk/Store/Protecti...per-step-1
Post #700283 11th Apr 2018 8:48pm
DAZ110
Think this is the back plate you need to bolt to your tow step:
https://dixon-bate.co.uk/products/gb/shock...coup-.html
Bare in mind that if you do any green laneing the back plate will hang down quite away and may catch on the ground. You can mount it upside down so it doesn’t hang down as far, but then it sticks up above the step which might be a problem.Rolling Eyes
Post #700285 11th Apr 2018 9:02pm
MudHugger
Thanks for all the advice guys. Really useful.
I have the 100mm version as I didn’t want to drop to be too low in case I go off roading.
So it seems the 150mm version will fit.
Does anyone know how much lower it will be. I’m presuming that the 150mm will be 50mm lower?
Thanks
Post #700305 11th Apr 2018 10:31pm
