![]() | Home > Tdi > Clutch flex hose securing nut size |
http://www.allbrit.de/UNI.cfm?PAGE=756646&SPRACHE=EN
7/16 UNF half nuts 5/8 UNF half nuts Last edited by dorsetsmith on 9th Apr 2018 7:49pm. Edited 1 time in total |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2706 ![]() ![]() |
Just a standard half nut of the correct thread is it not?
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 281 ![]() ![]() |
Cool! many thanks A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 632 ![]() ![]() ![]() |
Please check the tpi. 7/16" UNF should be 20. You mentioned the old one had 25. That does not match UNF or UNEF. 1995 Defender 110 CSW
1971 SIIA Lightweight |
Yup the 7/16 is 20tpi the "other:"one is 25 tpi Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
And of course stuff is still wrong.
The manual details the bits you need:- metal brake pipe from master cylinder to flexible pipe which connects to a wee metal brake pipe which in turn screws into the slave cylinder except ...... If you screw the metal brake pipe into the slave cylinder the other end doesn't fit the thread on the end of the flexible brake pipe. Everything bought specifying either reg number or chassis number. Solution ? Same as it was when Pte got the car in the 1st place, screw the flexible hose directly into the slave cylinder and forget about the intermediate metal brake pipe! Sigh! Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
