![]() | Home > Puma (Tdci) > Electrical connector advice please |
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 ![]() ![]() |
Strip insulation off and solder a wire onto that feed. No need to cut the wire just take the insulation off wrap the other around it and a dab of solder.
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Isn't that a photo of the trailer harness connector in the wheel arch? There is a permanent live in it for caravan use, I'm guessing you only have single electrics on yours so it's not used.
Behind the speaker panel inside the back of your car you should have a connector. On my 2010 USW it had a dual female spade connector. |
That was removed around 2012/2013 vintage. So this one may not have it.
GeeBee Member Since: 03 Apr 2018 Location: Perthshire Posts: 15 ![]() ![]() ![]() |
I did think of that but wasn't sure if this was the accepted method. Happy to get the soldering iron out thought - thanks for the advice. 2012 USW Keswick Green 110 |
Yes - if only it was still there in my 2012. Well spotted ZSD - that is the two electrics connector where the live feed terminates - so my task is to splice into it at that point and then feed a wire up into the area behind the tail lights. 2012 USW Keswick Green 110 |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6652 ![]() ![]() ![]() |
I think PaulMc does a terminal for these connectors, so you could fit a wire into the empty position on the mating connector to create your feed.
In that case then If you can't get a specific terminal as Martin has suggested (that would be my preferred method). Then I would cut it and use a duraseal butt connector.
https://www.autosparks.co.uk/electrical-co...-00mm.html You use them like ordinary crimp connectors but heat them up afterwards, this then shrinks and glues them to the wire making it very strong and totally water proof. Given it's location I wouldn't just solder and tape it, it needs to be more waterproof than that. |
