Home > Maintenance & Modifications > ..Hawkeye question..
Ecco
Malaysia 2014 Defender 110 Puma 2.2 DCPU Galway Green
..hi guys..im about to purchase Hawkeye diagnostic tool. As i can see from manufacturer web site, it does cover vehicles im interested in (RR P38 and Defender Puma 2.2)..
Now. Once tool is purchased, does it work on mentioned vehicles, or i have to buy some unlock key or something, for each vehicle in order to use Hawkeye with it ? For example, i have 2 defenders. So, if unlocking is needed, is that mean that for each defender i have to have separate unlock code (if it is needed) ? I will appreciate if someone who has this tool, put some light on to this before i do purchase.. Thank you guys..
Post #699525 9th Apr 2018 6:42am
cartoonhead
United Kingdom 2015 Defender 130 Puma 2.2 HCPU Corris Grey
It depends on the model of hawkeye - if it's the hawkeye total (https://bearmach.com/product-support/hawkeye-total) then you don't need any codes, it's pre unlocked for all the supported vehicles.
Post #699527 9th Apr 2018 7:04am
V8GPC
had to have a look as never heard of it, and came across the Land Rover Toolbox Video that may be useful to others
Post #699622 9th Apr 2018 4:46pm
Mdm
Hawkeye is easy to use and does most things you will need.
the smaller unit needs 1 unlock code per vehicle it is to be used on
the pro version has most of the lr product base on it.
Post #699660 9th Apr 2018 7:10pm
