Home > For Sale & Wanted > [Sold] 23k mile standard diff (sold)
LR90XS2011
2011 diff centre removed and chemically cleaned by Ashcrofts a standard 23k front diff centre, this has never been wheel spun and comes off a pampered land rover no noticeable wear or issues
£20 prefer collected, I have a pair of new timken bearings that any purchaser can have for an additional £15
I will make a forum donation if sold on here
prefer cash on collection I am near NEC but could post at cost in Ashcroft box
 DEFENDER 90 TDCI XS,
Post #699447 8th Apr 2018 7:12pm
Caterham
Hi,
can I ask a daft question. is it a 2 or 4 pin?
I thinks it 2 but if its 4 then yes please. Very Happy
Post #699462 8th Apr 2018 7:55pm
LR90XS2011
standard 2 pin (really 1) DEFENDER 90 TDCI XS,
Post #699468 8th Apr 2018 8:11pm
"pin" is actually an abreviation for Pinion.... so there's two on this diff (the small planet gears, or their bearings, or somesuch)
4 pinion has... 4..
Post #699520 9th Apr 2018 6:17am
Actually the diff has no "pinions" at all, it has two differential gears, two side gears, and one cross pin. All the gears are bevel gears.
The terms "two pin", and "four pin" as used in the context of Landrover diffs are misleading, inaccurate, and technically incorrect, but enormously widespread thanks largely to internet and its amazing ability to turn myth into fact!
Better terms would "two gear" and "four gear", or "single (cross-)pin" and "two (cross-)pin" (even though a four cross-pin diff generally has one cruciform pin). Regrettably it is highly likely though that the accepted misuse will ever be changed now.
Another example of this internet-driven butchery of technical language is the term "hawse fairlead", a non-existant and nonsensical alternative for the correct "plain fairlead". All the term "hawse fairlead" does is indicate that the user has no idea of the definition of the word "hawse"!
Again it is, sadly, probably too late to do anything about this.
Post #699531 9th Apr 2018 7:42am
Screbble
This is turning out to be a really interesting thread, and hopefully also acting as few free bumps Thumbs Up
I'm pleased Blackwolf has raised this point as over recent years I was convinced that my long-distant engineering memory was playing up more regularly. I too thought these were bevel gears, and that a pinion had 'square' teeth - albeit a pinion is the smaller of two meshing gears, with the larger being the aptly named 'gear.'
In any case, I fear you are correct Blackwolf, as not only are many basic engineering facts and nomenclature becoming lost over time, they are also distorted and in some cases completely 're-engineered' due to the power of the internet (or those uploading!).
I won't mention bolts and set screws Rolling with laughter
Back to the thread, I think it's a bargain and hope it sells quickly Thumbs Up
I do wonder if this would fit a TD5 90.... Whistle
Post #699574 9th Apr 2018 1:44pm
Screbble
PS LR90XS2011
I've sent you a PM!
Post #699576 9th Apr 2018 1:51pm
LR90XS2011
provisionally sold (if anyone else wants one see my other posts) DEFENDER 90 TDCI XS,
Post #699645 9th Apr 2018 6:15pm
Screbble
Payment sent Thumbs Up
Thanks for sorting Thumbs Up
Post #700393 12th Apr 2018 4:26pm
LR90XS2011
Sold DEFENDER 90 TDCI XS,
Post #700396 12th Apr 2018 4:29pm
Screbble
All arrived safe and sound today Rob.
Thank you very much for arranging the postage etc.
I am very grateful. Thumbs Up
I may get in touch with you before Christmas to help with my present wrapping as your packaging was a work of art! Rolling with laughter Thumbs Up
Thanks Rob,
Will
Post #701733 18th Apr 2018 5:20pm
LR90XS2011
£5 donation made to this great forum from sale
good luck with your diff rebuild DEFENDER 90 TDCI XS,
Post #701742 18th Apr 2018 6:28pm
