![]() | Home > For Sale & Wanted > [For Sale] Ultra gauge |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 431 ![]() ![]() ![]() |
Interested. Do you know which version this is?
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
EM plus V 1.2 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered. |
Does it come with the bracket and mounts etc? Any cabling that I'll require?
Thanks Ben |
Hi
No bracket, not sure how they mount really? I built mine into the dash, this was one I brought recently as a spare as mine was playing up, but not needed anymore. The cable is with it. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Ah no problem. Did a quick search and it looked like the one you bought on here came with a bracket and cable.
I'll probably mount it on a bracket for now and do the install later. I presume you followed something along this lines to install it? http://defender90xs.blogspot.co.uk/2014/09...ation.html What problems did you have with it? Get them all sorted? |
Yes, that’s the one
![]() Mines been in the dash for a few years now, but a while ago It stopped loading gauges, I thought it was the UG playing up? So brought this one from another forum member to replace with what I thought was my faulty gauge. After stripping the cluster down, I found one switch wire had come adrift, so turned out to be a simple fix! So, now no longer needed ![]() Wanted, Forward Control Anything considered. |
PM'd you.
