Home > Td5 > Newbie Fuel filter leak question |
Lowe Member Since: 13 Nov 2017 Location: Frederikssund Posts: 37 |
Just had a great weekend in Sweden hiking, on the way there the car developed a fuel leak from what appears to be on the forward facing side of the fuel filter.
Having 3 days to acquire new parts or fix the problem before Easter holidays, i ill have a quick look in the morning and take action from there, is there anyplace in particular i should start looking ? Mind you we are going on a 4 day trip on saturday, so it would be great to have it fixed ASAP. Without having to fab about.. |
25th Mar 2018 6:44pm |
Hi Lowe. Can our TD5 join your in Sweden sometime?!?!
Ok So to the filter. It is entirely commonplace for the aluminium filter housing to corrode at the pipe inlets/outlets. Usually on the filter side of the copper sealing washers. This causes fuel to leak out, air to leak in and can lead to a host of running issues. I would say 90% of TD5 owners will replace their filter housings for this reason. Be careful removing the pipes as the plastic securing clips can be brittle and difficult to release. Apart from that it is an easy job to replace the housing and filter. Only word of warning is to make sure you buy the correct housing for your Defender. If I recall correctly the Disco one is different. |
25th Mar 2018 7:25pm |
Lotus_esprit_s1 Member Since: 01 Oct 2014 Location: Uk Posts: 201 |
Replace it with a GORE filter housing, sorted once and for all then.
26th Mar 2018 7:19am |
Looks like i got of with a warning...
Seemed to be the filter it self that was leaking, so replaced it with a new one, and the hope that will work. |
26th Mar 2018 2:14pm |
Hi Bluebottle. Just checking you do have a TD5, right? That parts page looks to be from a TDI manual.
TD5 version: https://www.island-4x4.co.uk/fuel-filter-h...27772.html Last edited by geobloke on 8th Apr 2018 11:57am. Edited 1 time in total |
8th Apr 2018 11:46am |
bluebottle Member Since: 08 May 2015 Location: Not in my Landy enough! Posts: 705 |
Ah - yes - I do have a 2005 TD5, although superficially at least it looks like that in that it has 4 pipes, 2 either side.
The other 2 options on the Russian LR Cat link (page 4 of the sticky in General Chat) don't look anything like mine. |
8th Apr 2018 11:47am |
This is what you are looking for;
https://www.island-4x4.co.uk/fuel-filter-h...27772.html There is also an alternative Gore version if you want to go no OE: https://goreproducts.com/products/td5-fuel-filter-housing |
8th Apr 2018 11:59am |
Brilliant, thanks.
Now all I have to do is work out how to get the sheared bolt out of the chassis and pray the existing pipes are serviceable... |
8th Apr 2018 1:09pm |
Be very very careful with the pipes they can be quite brittle, as i found out...
Also worth double checking the part number is correct for your defender. There is a difference between the Def and Disco part numbers. Give LR a call if you are uncertain. i believe it was only the arrangement of the brass connectors, in particular the position of the one way valve. |
8th Apr 2018 1:16pm |
Ok, ive gone for the GORE housing since I intend to keep the truck forever.
Now I need advice on tools please - I’m guessing my best bet is to drill out the old rusted bolts and then replace with a shiny new rivnut. To do this I would be best to remove the wheel - so I’ll need axle stands and a rivnut tool. Ideally this should still be cheaper than going to a garage! Will a pair of 3 ton stands be enough to hold up the back axle of a 110 CSW? Anyone know from memory the bolt size for the fuel filter housing? M8 or M6? Cheers! |
12th Apr 2018 9:22am |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1628 |
Click image to enlarge Move the housing out of the way and heat the bolt with a blow torch and take your time, rotate the remains back and forth with a pair of mole grip SLOWLY! and they normally come out easy enough with the mole grips. Normally nothing wrong with the bolts, it’s the corrosion between the housing (aluminium) and steel bolt that explodes and snaps the head off! Rest of the bolt will be fine. Watch the plastic pipe ends soak and clean them out first don’t go at it like gorilla! Run a tap down the threads before you fit new bolts! |
17th Apr 2018 10:12pm |
Thanks Nick, unfortunately I don’t have a blowtorch so I’ve had to make do with a drill!
I have, however, got a set of bolt removing bits so we will see how they fare tomorrow... |
17th Apr 2018 10:21pm |
DIY plumbers blowtorch (under £10) will do the job! They’re in rivnuts so trying to extract them with drilling or extractors will put you in a world of hurt and end up spinning wrecking the threads! Trust me I’ve done lots of these mate.
17th Apr 2018 10:32pm |
Damn.
I’ve now drilled out the bolt, made hole big enough for a new rivnut. A big thank you to Keith at Challenger 4x4 for giving me a handful of them (M8 incidentally) when I popped in to get a fresh filter to put on when - if - I ever get this finished! Can’t fit rivnut because the thickness of metal is too great for the rivnut to squash and bite. I’m now in the interesting position of having to take the rear plate of the housing shield off the chassis... obviously the special order Land Rover bolts with heads made from cheese/chocolate were fitted in the factory, so they’ll round off nicely. Honestly, it’s like LR designed everything down to the lowest quality possible to get away with the job Either that or they hoped to diversify into divorce law, my better half is distinctly unimpressed with how long this is taking me! |
18th Apr 2018 10:50pm |
