Home > Maintenance & Modifications > Home Made Rivnut Tool
Page 2 of 3 <123>
Sorry to re-live this thread again but I have a couple of problems I have on mine for the rear ladder. There are two at the top that spin that are barely possible to remove the bolt but luckily can access the rear. And four at the bottom none of these spin which is lucky but one seems to come out forwards a little. The top two I'm thinking of removing to fit a stronger mounting because I don't think they are strong enough anyway but for the time being can these just be tightened up and they will be fine? Never attempted to try this because I haven't had a tool nor attempted the home made version.
So will they be okay if just tightened up for now? TheThunder Rolls🇬🇧🇺🇸
Post #263587 3rd Sep 2013 10:09pm
Yes, it's ok to tighten them. If you can get to the back, of course, then nuts and bolts may be better. Darren
Post #263588 3rd Sep 2013 10:14pm
That's what i was thinking for the top two. AFAIK LR fitted them but IMO are not strong enough for purpose. There isn't even a washer on the back. Shocked TheThunder Rolls🇬🇧🇺🇸
Post #263590 3rd Sep 2013 10:21pm
Not having a washer on the back isn't that big a deal, assuming they're fitted properly. They are designed to fit into panels where access to the rear isn't possible anyway. Darren
Post #263592 3rd Sep 2013 10:24pm
Very true, but there is access on these two and I get the impression it was done quickly just to get it on. TheThunder Rolls🇬🇧🇺🇸
Post #263594 3rd Sep 2013 10:26pm
Eric L
France 2007 Defender 110 Puma 2.4 SW Alpine White
ingenious ! Bow down Bow down December 2007 110 Defender. 106000 KM
Post #296078 5th Jan 2014 6:19pm
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Old post revival I know, but as a 'Sticky' I thought this maybe useful. Image below is taken from the LR OEM Lamp Guard fitting instructions. Shows a very simplistic method of fitting rivnuts. Haven't tried it myself (yet!) but it bears some resemblance to the method described by Litch regarding the flat metal strip.
Post #426849 28th May 2015 10:17am
X4SKP
Hello All
This is worth a look if your working out how to approach this...
Both with and without a Tool... fitting the Defender Front Light Guards
also gets a mention.
The usual requirement of needing 3 hands when using a home made Tool
is also refereed to... Shocked
 SKIP
Post #426860 28th May 2015 11:27am
schweps
Turkey 2005 Defender 110 300 Tdi HT Alpine White
Hi,
For small size rivnuts (al or st) i use ordinary pop up rivet tool by some little changes.
What you need is a threaded rod with a suitable length and same size with the nut. A thick washer and a normal nut (may be two).
If you remove the capsule holding the jaws and the spring, you can easily insert the rod. All you need is stretching movement of the rivet tool that it is still capable of.
Post #464569 19th Oct 2015 8:59am
LoveTheMud
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Santorini Black
having successfully ruined my poor fathers hands (blind leading the blind) and both of us getting blood everywhere, i say this...if you are going to use the crap method they give you in the destruction manual, then dont...its easier and kinder on your hands to buy the tool with the many mandrels needed... you wont regret it and the car is held together by rivets so there is always another mod or fix that requires them Smile defo worth the investment
Post #506995 22nd Feb 2016 2:23pm
Coatesyyy
That's brilliant, thanks Thumbs Up
Post #652603 25th Sep 2017 10:56am
GrouseII
United Kingdom 2008 Defender 90 Puma 2.4 HT Coniston Green
Hi
As others, I apologise for opening this up again but I have spent a frustrating afternoon shearing bolts and rounding nuts using the DIY method. See pic.
It is only a 6mm but it hardly flexes until the bolt shears or nut rounds or my muscles give in. My question is that is it possible some (cheap) rivnuts are rock hard and will not work with the DIY method. I only have two to do so dont want to waste loads o money on a tool.
Perhaps someone can recommend a 'soft' brand of riv nut Smile
Thanks
Grouse 2
Post #699246 7th Apr 2018 6:56pm
TACK
Feel your pain. I have found exactly the same in the past and gave up after about only 50% success. Same issues as you have had. It only to get you out of trouble but anything more than that, buying the tool is the way to go👍
Tack
Post #699262 7th Apr 2018 7:24pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
It’s almost impossibly to crush the steel rivnuts with the simple home made tool. However the aluminium rivnuts will work well with the home made tool.
Post #699303 7th Apr 2018 9:21pm
miker
I think your problem lies with the nut and bolt, not the rivnut.
Most coach bolts are 4.8 grade at best, which is roughly comparable to mature cheddar.
I've done loads the DIY way using decent 8.8 bolts and grade 8 nuts.
Equally a short armed rivnut setter is only £35 on Amazon and works well!
Post #699397 8th Apr 2018 1:49pm
Page 2 of 3 <123>
