Home > Td5 > Power problems in rain
Kst80
I’m looking for some advice please. Twice this week, after driving at 55(ish) mph on motorways in fairly heavy rain I have had an issue with the engine stuttering as if it had a fuel issue. After it happening again today would I be correct in thinking it may be electrical with water getting in somewhere? Both times I have pulled off the motorway and after a few moments it seems to clear, although I believe it may have a very slight stutter (but I may be imagining that).
Thanks all.
Post #699190 7th Apr 2018 4:16pm
mk1collector
How dry is your air filter when the stuttering starts? Ray
My build thread
Post #699213 7th Apr 2018 5:14pm
Kst80
Didn’t think to look at 5he air filter, I will however do so. Is that a problem with these? I know water gets in everywhere else Laughing
Post #699237 7th Apr 2018 6:15pm
mk1collector
Don't know if it's a common problem, it was just a thought if you were driving in heavy rain. Ray
My build thread
Post #699256 7th Apr 2018 7:13pm
Kst80
Thanks I will check.........I’m sure it will rain soon!
Post #699265 7th Apr 2018 7:33pm
geobloke
Raised air intake or Snorkel? Forward facing scoop type RAI heads (Safari and alike) have been known during heavy rain to allow water in to the filter box, soaking the filter. If you have a scoop type RAI head then turn it backwards to prevent this. Mine is backwards through most of the winter months to prevent this issue.
It would also be worth going over the vehicles earthing points, cleaning them up and putting a direct earth from the ECU to the negative terminal of the battery. May sound a little left field, however changes in humidity can do strange things to ECU controlled vehicles. Worth a try anyway.
Post #699333 8th Apr 2018 8:34am
Kst80
Thanks, it has a Mantec plastic jobby raised intake. Not long fitted so could be on the right track. Lots of rain on Tuesday so I will have a good look now and again then.
I will check the earthing as well, I opened the battery box as I thought that’s where the ecu was, I’m guessing it’s under the drivers seat? Or as on my 300 in the middle? I shall find it and check.
Post #699337 8th Apr 2018 9:19am
Kst80
Thanks peeps, checked air filter.....which is now drying out.
Going to assume plastic jobby needs better sealing, or could it get in elsewhere ?
Thanks again
Kev.
Post #699348 8th Apr 2018 10:33am
geobloke
Super. Glad it will be an easy fix. I do recall that Pumas had a big issue with the Mantec/LR plastic job snorkel and rough running in rain... would be worth search or two...
Post #699366 8th Apr 2018 12:19pm
Kst80
Funny thing is when we got our first defender, the 300, the guy we bought it from had fitted the Same snorkel and made a point of saying he had sealed it properly and most people don’t bother......I thought sales pitch but maybe it wasn’t! Embarassed
Post #699368 8th Apr 2018 12:41pm
jonny2tanx
United Kingdom 2005 Defender 110 Td5 XS CSW Alveston Red
Thanks again
Kev.
I had the same last year driving through Poland in torrential rain, but I don't have a RAI fitted. Air filter was sodden with water being ingested through the air intake. Not sure if your RAI retains the original pipework from the wing to air filter but if so there is meant to be a drain valve in that pipework to drain off water. Mine was covered in Dinitrol, by the look of it, and was not allowing water to drain
Post #699372 8th Apr 2018 12:52pm
Kst80
It does retain the pipe work, so I will check that as well. Cheers Very Happy
It is absolutely soaked and currently drying out indoors!
Post #699402 8th Apr 2018 1:55pm
mk1collector
Might be worth ordering a new filter and as above check the drain plugs along the pipe work for blockages. Ray
My build thread
Post #699403 8th Apr 2018 2:15pm
miker
Mine has acceleration problems in wet weather. I have to keep moving my accelerator foot to avoid the water dripping on it!
Post #699404 8th Apr 2018 2:27pm
mk1collector
Post #699408 8th Apr 2018 2:53pm
