![]() | Home > Td5 > Defender TD5 cruise control.....confused! |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 721 ![]() ![]() ![]() |
The red wire on the Speedohealer needs an ignition live, the black cable needs an earth which are besides the ECU. I cut the yellow/white wire coming from terminal B13 on the black ECU plug, connected the white wire of the Speedohealer to the speedo gauge end and the green wire to the ECU end.
The instructions to programme it are on Healtech's website https://www.healtech-electronics.com/ht_sh...or_en.html |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
Cheers fella
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
For transfer box correction use it should be wired in either at the engine ECU or behind the instrument pack.
Thank you 😊
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 259 ![]() ![]() |
Hi All,
how do you know what to adjust the signal to ? as you are not changing the dash speed, thanks, Dave Dave |
From a sat nav gps speed
amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452 ![]() ![]() ![]() |
If you have discovery transfer box like me it’s - 15 % as this is the difference the transfer box makes
DiscoSmiley Member Since: 31 Mar 2017 Location: Alberton JHB Posts: 5 ![]() ![]() |
Looks good. Let us know once you get it working. I still need to do mine.
Had mine working for over a year now. Works really well and is a huge bonus on long drives.
It made the 1000 mile non stop trip down to Spain last year much more bearable. Great mod done using this guide ![]() ![]() |
thanks but thats not what I meant, if you fit the 1.2 ratio, the speedo stays true assuming you keep the same speedo drive gear. If you change the tyres you adjust the speedo healer to get the speedo true to a GPS but the question was what you set it to to 'fool' the ECU, not adjust the speedo but yes as 'amondeggs' suggests -15% is logical so the engine ECU knows no difference. many thanks, Dave Dave |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1369 ![]() ![]() |
I’m now up & running. Thanks to Harry & Grafty
Excellent
![]() ![]() ![]() Click image to enlarge ![]() Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
All my switches are used so I have a darling switch above RHS speaker on dash
Finally got mine wired up today and on a few short journeys it seems to work perfectly
![]() My build thread http://www.defender2.net/forum/topic17615.html |
