Home > Technical > Jack advice for upcoming trip.
Page 2 of 2 <12
leeds
If using High Lift jack a jack mate will lift certain wheels up without raising the suspension system.
If travelling consider a folding axle stand plus also load spreader plates for any jack or axle stand. Takes up little room but increases safety tremendously if working on vehicle/changing wheel.
Also slide spare wheel under vehicle whilst carrying out work as a safety precaution.
Better safe then sorry and a trapped hand/leg/head under vehicle.
Brendan
Post #695061 20th Mar 2018 11:03pm
Welkman
Cheers Mate Smile
Post #695498 22nd Mar 2018 9:00pm
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
Bottle jack and a Tirfor and you can't go wrong
Post #695783 23rd Mar 2018 11:16pm
+1 for the Tirfor - my favourite piece of off road kit...and useful in the garden too:
Post #695858 24th Mar 2018 11:17am
legin
Supacat That's a rare bit of kit only ever seen a wire drum fitted to the side of a Tirfor in a war museum before.
Post #698376 3rd Apr 2018 10:38pm
Well thanks for making me feel old Embarassed
I bought the drum (coilamatic) new with the Tirfor itself. Having previous experience with Tirfors and the battle of handling 30m of loose cable in/out of a vehicle multiple times, it was top of my list of options to get with one.
I must admit, I've never seen anyone else with one but wouldn't be without mine. Thumbs Up
Post #698484 4th Apr 2018 1:27pm
I always carry at least one. Mind you I find the old wheelbarrow/motorcycle tyre technique more convenient than the coilamatic drum.
Excellent tools! Thumbs Up
Post #698494 4th Apr 2018 2:04pm
MartnH
Australia
My high lift jack almost killed me
I now respect this piece of tool highly...
I still carry one but usually I will use bottle jack first....
I guess, you won't understand what I mean till you experience it yourself....
Post #700493 13th Apr 2018 8:11am
Pilgrimmick
I have driven Land Rovers all over the world, used the OEM jack, high-lifts, air-bag jacks, tirfor winches, electric winches and hydraulic winches. None of them is better than the others, they all perform different tasks.
The air-bag I would limit to sand and soft ground, winches need trees, the electric and hydraulic ones need the engine running (I know the electric runs off the battery, but unless you have a very good set up for battery charging and capacity, it is surprising how little you can do before the battery is flat) and an anchor. Tirfors need a lot of effort
High lifts are may preferred option, but are plain dangerous if you are not experienced with them.
To give an answer we need to know what your plans are, the ammount of off-roadin, the ammount of tracks etc. Are you travelling in a group, do you have a winch?
The one thing I would say, leave the trolley jack at home. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #700505 13th Apr 2018 9:08am
The factory pillar jack gave out on me! Got rid now but half way up and it slid all of the threads down in seconds!
Luckily as most would, wheel still on and nothing underneath at all, most importantly not me underneath.
Personally I’d never get underneath unless wheels are on or garage lift.
I wouldn’t even trust axle stands, although they are perfect for general work so long as not your not under it. WeWillWin🇬🇧🇺🇸
Post #700544 13th Apr 2018 12:21pm
I thought the same way as you with regard to feeling safe underneath having the wheels on but, if you stop a second to think about it, the tyres are just a form of air bag jack and whilst failures may be rare - I've never heard of one failing with someone underneath - they conceivably could.
Post #700547 13th Apr 2018 1:22pm
zsd-puma
Even garage lifts can fail - although most have a safety system. And two post lifts rely on the car being positioned on them in a balanced position - removing gearbox can throw the car out of balance and tip it off.
Decent axle stands are perfectly safe on hard level ground. Decent ones will have an appropriate foot print to prevent them falling over. Problems come when people try using them on a camber or soft tarmac.... ie at the side of the road.
Lifting nearly 3 tons with anything is dangerous if the tools are of poor quality or aren't used correctly.
Post #700885 14th Apr 2018 11:33pm
Guy
ARB have come up with a new take on the off road farm jack. Looks good...
https://www.arb.com.au/recovery/hi-lift-jacks-accessories/jack/
DINGO - '99 Discovery 2 V8 with 300Tdi transplant, chawton white. Repatriated from Australia and expedition prepped.
**FOR SALE**
SHARKY - '06 Discovery 3 HSE Auto, bonatti grey. SOLD.
GEORGE - '99 Discovery 1 300Tdi Auto, willow green. Daily driver, travel companion, part of the family! SOLD.
PINGU - '96 Defender 110 300Tdi station wagon. SOLD.
Dream LR - 130 pop top station wagon camper.
Post #700948 15th Apr 2018 9:43am
ZSD - Indeed that’s an issue, too much purchase on something on the ramp and wouldn’t be good.
Safest thing really is keep out from underneath as much as possible, and never rush always be mindful if you do. WeWillWin🇬🇧🇺🇸
Post #700964 15th Apr 2018 11:24am
Page 2 of 2 <12
