Home > Puma (Tdci) > Engine warning light after clutch change
phildick
United Kingdom 2012 Defender 110 Puma 2.2 CSW Orkney Grey
Just had a new clutch in my 2012 110. When I got the back the engine warning light came on after about 10 miles. I took it back(local indy) and they said it was the cat overheating. They cleaned some contacts and road tested it. However the light came back on again once I got it back and got it fully up to temp.
Any ideas what they have done?
Post #698372 3rd Apr 2018 9:36pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
If the engine light has come up there Will be an error code logged. Do you happen to know what is was? a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #698408 4th Apr 2018 5:29am
phildick
They didn't tell me the actual code. They had a diagnostic tool plugged in and said it reported the cat overheating. It is also in and out of limp mode.
Post #698423 4th Apr 2018 7:35am
Tdi4
Limp mode is a generic outcome of very very many different Problems. I’am failing to see any connection between the clutch and the cat except when removing the clutch they take out the exhaust. Perhaps wiring then? Or temp sensor? Hope that others can be of more help. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #698428 4th Apr 2018 7:50am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I take it that they checked the EGT sensor wiring,
Sounds to me like wiring or a plug has come adrift around the DPF?
Seems a bit odd that your EML wasn’t coming on before the clutch change,
Get them to check the wiring again. Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #698453 4th Apr 2018 9:13am
phildick
In the end they said it was a sensor had failed. However they replaced a heater element which goes into the DPF I believe.
Post #703284 26th Apr 2018 11:17am
NickMc
You have to at least disconnect it to change the clutch so I would be 95% sure they’ve caused the fault.
Post #703394 26th Apr 2018 7:55pm
phildick
In the end they had it in twice, first time for two days second for four days. Charged me only for the new heater element which was 60 odd quid.
Post #703434 26th Apr 2018 9:17pm
