Home > Td5 > Handbrake Cable
adeparko
Scotland 2007 Defender 90 Td5 HT Sumatra Black
Handbrake Cable
Looking for some advise on replacing the handbrake cable on a 2004 TD5; is it something that can be done easily enough DIY?
The garage I usually use is booked up for the next 4 weeks and my wife is wanting it fixed sooner Laughing
I'm OK with spanners, had to learn quick owning a Discovery 1
Any links, tips or advise would be great
Thanks
Ade
Post #698214 3rd Apr 2018 1:44pm
landroverdiver
Hi
This is a topic that I have been saving in my watched threads, as I will have to do mine. So, I have copied and pasted someone else's text below (I'm not skilled enough to put a link) Hope this helps.
Mike
Mine snapped a couple or 3 months ago, (TD5 CSW) yes you do need to remove the prop, which is helped massively by having the right tool which is about a tenner online. getting the retaining clips back on the handbrake shoe retaining springs is a PITA, again I think there's a tool for it but I only had pliers etc. apart from that pretty straight forward.
Propshaft bolt removal tool helps ( you may have slim sockets but I struggled to get mine on )
SKU: DA1119
Excl. Tax: �9.50
Incl. Tax: �11.40
Bought from Paddocks
Post #698230 3rd Apr 2018 3:33pm
adeparko
Running into problems trying to change the cable today
Bought a tool to remove the prop shaft but it doesn’t cover the nuts?
I also can’t get a spanner on enough to remove
Anyone advise?
Thanks
Ade
Post #701011 15th Apr 2018 2:29pm
dorsetsmith
9/16 AF ring spanner
Post #701013 15th Apr 2018 2:49pm
I use a 9/16" AF Snap On flex socket for propshaft fastenings, it works far better than the supposed special tools.
https://www.snapon.com/Industrial-Certific...ex-Sockets
I can't link to the specific socket since thd Snap On site is down for maintenance at the moment.
Post #701014 15th Apr 2018 2:58pm
roel
I use a 14mm socket that I grinded down a little and lossen the nuts when the are on top. Roel
2003 90 Td5 (2009-now)
Post #701128 15th Apr 2018 9:16pm
adeparko
Thanks for the suggestions Bow down
All sorted with new cable and shoes. Hopefully keep the wife quiet for a bit Laughing
Thanks
Ade
Post #701152 15th Apr 2018 9:52pm
Screbble
Good man Thumbs Up
Glad it went ok in the end.
Might get round to looking at mine one day.....
Quite like those flex sockets Blackwolf Thumbs Up
Post #701160 15th Apr 2018 10:19pm
