![]() | Home > Td5 > vnt turbo |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
You need a proper remap to take advantage of the VNT really. 02' 110 TD5 Double Cab Rebuild Thread
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2209 ![]() ![]() ![]() |
Thing is you appear to have just bolted bits on hoping for power.
TD5inside is one guy working near enough worldwide so yes is very busy. Their VNT must be installed with his mapping or it wont run correctly. |
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 ![]() ![]() ![]() |
I agree completely, it has to be remapped with new VNT turbo. That's obvious.
If he is that international, then his website should reflect actual buyin options and not contact forms. I have a NNN ecu, but its calibrated for 15P engine, not 10P i currently am running... |
Gerry Member Since: 22 Oct 2017 Location: north Ireland Posts: 35 ![]() ![]() |
Without the ECU remap, and the auxiliary boost box to fool the ECU into allowing greater psi you're really not going to see great benefit from those additions.....but with a proper remap and the equipment you have you'll be lightning quick.
![]() I have a TD5inside remap done and cant recommend the guy highly enough, I'm fortunate enough to know one of his clients in the competition circuit who let me know when Jose was going to be local. |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 645 ![]() ![]() ![]() |
Time has changed a bit - there are better ways than fooling the ECU with boost box. You need the proper tuning file for your NNN ECU (there are at least 2 different HW versions needed different map - older NNN000120 and newer NNN500020 or NNN500250) and your engine. Without this, it will not work correctly.
After uploading the right file into the ECU, it is just the right set of the turbo output pressure regulation. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo ![]() |
Interesting, thanks.
I found CR have allowed allisport to sell their GT2058 turbo, but is it worth it, or the VNT better?
My alternative is to score a hybrid BMW VNT turbo and adapt it to fit my engine. Make an 2 top and 1 bottom bolt pattern to 1 top and 2 bottom adapter. I will get all the needed hoses, banjo bolts and drainage. The BMW is a GT2256. which should flow more, and just as quick. No oh but thats chinese crap plz, they are all basically chinese these days... |
What are you expecting to acheive by changing to another VNT?
If you want to use a different turbo you need a remap suitable for that turbo. You cant just bolt one on and expect it to work with the standard map. The boost box is presumably just preventing the ecu sensing overboost and going into limp mode by masking the reading of the MAP sensor? It is not helping the turbo spool at lower revs as it is not changing any of the fuel mapping. Additionally it doesnt sound like you are even running the correct map for your engine. 10P and 15P use different injectors and pressures. I would suggest you get it properly remapped. 02' 110 TD5 Double Cab Rebuild Thread |
For the love of God, i agreed to the remap with new turbo. Lets move past the stupid remap issue...
I am runnin the correct map for my engine, i have a msb, which originally came with my 10p engine, and a nnn ecu which is calibrated for my 15p engine. The 15p is sittin in my warehouse. The 10p is installed in my defender. We traced the issue to the injector wire loom. Two cyl were not firing. So that may drop the sweet spot down. Now back to my thread going to the Bmw VNt cause it is available, more fordable, and just needs fabrication of parts on my end to make it fit the Defender exhaust manifold. I will then send my nnn ECU file for recalibration of my new turbo on my 10p engine, probably storm, or alive. Retaini my 15p file for later if i feel the urge to swap. Again i currently have the correct map for the correct engine. I just am lookin to lower my sweet spot from 2500rpm to 2000, if not lower. |
And with that attitude I am out.. 02' 110 TD5 Double Cab Rebuild Thread
Problem is you don't seem to be listening. It does not matter if your TD5 is mapped or not, if you change the turbo the mapping has be be adjusted accordingly, the torque curve can also be adjusted.
Just slapping on a BMW VNT won't do much without adjusting the mapping to suit it. Best bet is to wait for Jose to reply (which he will eventually, Sunday/Mondays are usually his email days) get the CR VNT (race spec one if you want which is slightly larger) fit it and have him send over a suitable map. Ideally you need to dump the PSI tuning box & the boost box. The tuning box is just going to dump more fuel in at certain revs and potentially cause issues down the line. The boost box should be removed & replaced with an uprated MAP sensor and the boost limit electronically raised. If I am wrong this is your set up - Standard map VNT PSI box Boost box I agree TD5inside need to spend a little time/cash on some admin but Jose appears to be a victim of his own success, he certainly wasn't this busy a 14 months ago when he mapped mine (which actually needs to be adjusted as is smoking a little too much) |
Hello Naf,
I probably cannot say here that the PSI power box is better then the best tune you can find. But clearly a lot off people here don't understand it. ![]() As you have an water/methanol injection system I think you know what you are doing. A standard tune also looks at the inlet pressure and temperature to calculate the max fuel injection that is why just increasing the turbo pressure will give you a little more power. If you install a VNT turbo and adjust it properly you will get more boost at a lower rpm. As your psi power box will kick in at about 1300 rpm you will have an good effect off it in Mr ZULU mode. I have my PSI power box also behind a switch but also behind a small piece of chinees electronics. My PSI power box only kicks in if I am at full throttle. It measure the Throttle voltage from track 1 and kicks in at 4,5 V. I hate the always kicking in at 1300 rpm as that is were I happen to drive a lot in town. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
I listened, and i understand the reasons behind the remap, even with a hybrid turbo vs stock. Diesels like lean burns, but when you pump in more air, you have to also pump in more fuel, the ecu has its limits, and when the limits are met, it doesnt offer you more than what it is programmed to give. I have tuned LS engines, and just correcting the MAF to minimize the trim goes a long way in delivering more power and a stable idle
My current setup is this 10p Engine unknown condition Hybrid stock size turbo PSI tuning box Sprint Boost throttle Alive uprated Map sensor I do not have the boost box installed, as the new MAP sensor helps fix that problem. I am looking to upgrade to a VNT turbo, to drop my sweet spot down from 2500rpm to around 2000rpm if not lower. This way i am not constantly revving the engine to give me enough power to keep up with traffic. Jose did finally email me last night, and and you are right he is a victim of his own success, his reply was very unprofessional and insulting. I initially emailed him on Nov 2016, with an uncountable amount of web forms filled out, no replies were received. In Jan of this yr i got in touch with CR turbo over fb and they said i have to use him, i replied back, i am not going to wait forever, They told Jose this, and he pushed my email to the bottom of the list for three more months. He mentioned this in his reply. Its not my fault i found work in the middle east, its not easy to find great ppl who do great work or offer great products, because we all know there are ppl out there who will take your money and offer you less than what they promised I have been nice and patient, but lets be honest no one is that good to act like that. In today's economy, you have to pick your battles. And with the internet, everyone is your competitor. I declined on his help, and wished him well, i will not work with a prick how thinks he is the center of the universe, i am surrounded by enough of those ppl here. I will buy a new Nanocom for my td5 NNN ecu and install my 15p engine which i rebuilt with new rings bearings and gaskets. I took the time and ported out the head to match the intake and exhaust gaskets. Its nothing crazy, but i merely allowed more flow of air in, and removed all the sudden obstacles in the way that may give any restriction. I will log and remap the ecu to fit my setup or may even ask for Storm tuning to assist since they come highly recommended, who also have replied to my emails... Alive is fine, but i feel since they are industrial giants, they just do copy pastes and its either you take it or move on. I did find another company called Monster, who offer more affordable remaps, and they guy on the phone sounded like he was on the ball. I have AFR, Boost, rpm, and EGT gauges hooked up to my engine, so i may log all the parameters and later review via Innovate motorsports logging program.
If you are not going to read the other posts, and just type what you want, you are not being a positive contribution to this or other threads. Five ppl in five posts including you TWICE said to remap, and one other member said exactly what you did, add a boost box. Madtom corrected him and mentioned with the new NNN ecu, you are able to program the boost to be higher, deleting the need for a boost box. Last edited by Naf on 4th Apr 2018 8:31am. Edited 1 time in total |
