- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
itolond
Aux battery hook up best practice | |
Hi Forum,
I have my Aux battery ready to go in and this raised a few questions.
Amp runs direct fused to Aux battery ( all good here) there is a power live wire from the stereo head unit which when on will activate the amp ( all good)
The question is around operation. Supposing I was in need of a mid street rave () I would want the head to run its power from the aux without key in ignition, again ok..
But for the lion share of time I would want the stereo head to operate with Acc ( eg on and off as per normal)
I Guess a Aux rocker switch would be the simplest SPST or similar but before I commit to wiring put it out there for comment and akterbatives
29th Mar 2018 10:11am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
