![]() | Home > Puma (Tdci) > Standard alarm on back door? |
Does the rear door have a switch that operates the interior light? If not, that's why it doesn't trigger the alarm. If it does, then there's a fault somewhere as the door switches all work in the same way and it's not a complicated arrangement. Darren
By default there should be one fitted, although mine had gone missing before I bought it.
It's a purple wire. |
GrouseII Member Since: 29 Dec 2017 Location: Bucks Posts: 37 ![]() ![]() ![]() |
Thanks.
When I said it was basic, it really is ... no interior rear light (which is a pain) I guess I will have to remove the rear door fascia to go in hunt of the purple wire, is there any kind of wiring diagram available online that might show if and where my variant might need one should it be missing, or do i need to buy a Haynes manual? Grouse2 |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 ![]() ![]() ![]() |
Hello GrouseII
Best Photo I have...2.4 Puma Rear Door but with a rear Trigger Switch + an Interior Light... ![]() This is the general arrangement, the wire from memory splits off from the loom supplying the Rear Door (Heated Window... I guess that's a No for you, and Rear Wiper, probably a Yes ![]() The bracket holding this looms entry into the rear door also acts on the Trigger Switch when closed the wire you are looking for is within your 90 OS Rear Interior Panel Work... (Not the Rear Door) A Switch and 'Push Plate' bracket can easily be retro fitted...hopefully you will have some bits in place already. ![]() Click image to enlarge Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
Lotus_esprit_s1 Member Since: 01 Oct 2014 Location: Uk Posts: 201 ![]() |
I too have a base model 2.4 Puma 90 hardtop, Mine didn’t even have a heated rear screen or rear wiper let alone a rear door loom!
The standard rear door push switch which it is fitted with from the factory operates the front interior light which in turn sets off the alarm. |
Thanks Skip
Now, before I atttack the door facia with a flat head screw driver and lots of leverage, experience tells me i'll break all the little plastic lugs and it'll never fit back on again ... properly. Aside of removing the grab handle what is the secret to getting this panel off so it will go back on again? BTW. Chuffed you went to the bother of taking the photo for me ![]() re Lotus comment that is probably good news that there is a fault rather than missing as opening my rear door does NOT put the front interior light on. ![]() |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1325 ![]() ![]() ![]() |
Hi GrouseII
I can't make it out from your photo, but do you have the black bracket already fitted with the flat section that would push in the door contact switch as per X4SKP's photo? Even if not, you may not need to remove the rear door trim to fit it as the bolts which hold it in place appear to be accessible without removing the trim. I stand to be corrected on this, but I think the wire you need to find for the door switch will be behind the rear trim panel if it is there. I don't think it will be in the door. The door switch is mounted to the fixed part of the bodywork, not the door. The door switch would fit in the hole in the bodywork I can see in your photo above where the black flexible wiring conduit leaves the bodywork and goes across to the door. |
Thanks gentlemen
Now I understand ![]() Yes, I am missing the little plunger switch in the body but oddly do have the relevant hi-tec bracket to push it. Weird how it is missing, anyhow I now have the knowledge I need to make secure :'D may be not, my landrover rear entry! Thanks to all again Grouse2 |
