Home > Off Topic > What Wheelbarrow (how exciting) |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17484 |
I have no experience of that type of barrow but I would have thought that the looped handle would be awful to use. Generally when I wheel a barrow I stand between the handles with my arms more-or-less by my sides; with that one you'd have to have your hands in front of you which, I would have thought, would be exceptionally tiring.
27th Mar 2018 3:08pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3773 |
^ Good point did not think of that...
27th Mar 2018 3:11pm |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
That one looks pretty good!
I have got through 3 recently. The only one that survived good punishment was a Chillington one - and it's still going strong after 20 years! 2 newer, cheaper ones died doing a build project, but the chillington's still going strong http://www.haemmerlin.co.uk/products/performance-series/flexi-up/ They do a twin-wheel one too http://www.haemmerlin.co.uk/products/first/twin-kit/ It's one of those "buy cheap - buy twice" things. Get a good one and you will have it for many years Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) Last edited by MartinK on 27th Mar 2018 3:50pm. Edited 2 times in total |
27th Mar 2018 3:12pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3332 |
Check out Haemmerlin.
Edit: Martin beat me to it. |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
The two-wheel versions are not as manoeuvrable, you can't lean them to go around corners. Also, agree that handle doesn't look easy to use.
Try going to your local agricultural merchant and try a few out. James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
27th Mar 2018 3:15pm |
That one looks very similar the haemmerlin one and it's £65 for air tyres which I upgraded on the other one to puncture proof.. so at £76 with the puncture proof tyres...
Your right I've had cheap £25 / £30 ones and while they do the job they don't last. Good point about where you stand to shift it? will the handle on the double ones be worse than two seperate 'std' wheelbarrow handles? |
27th Mar 2018 3:18pm |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1364 |
Last wheel barrow I got was £15 and its still going strong 4 years later. Sod paying £92 for one
James your right....
Trip to try wheelbarrows out though..... :ro lllaugh: |
27th Mar 2018 3:21pm |
AJC depends how much you use it I....
I finished ours off moving 10 tonne of gravel around the drive probably over filling it far too many times I guess I should be more careful storing it also though |
27th Mar 2018 3:24pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2531 |
Any serious petrol head needs one of these.
Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
27th Mar 2018 3:58pm |
Chocolate Member Since: 18 May 2012 Location: Berkshire Posts: 153 |
I have a 2 wheeled version which the tyres have gone flat.
Used it a bit, but it wasn't as useful as I thought it would be. The wheel base being wider is no use when going down narrow paths or uneven ground. Turning is more difficult as the tyres are dragged around. When pushing you can be thrown to one side if a wheel hits an obstacle. Now looking at single wheel solid wheels. Stable when loading though. 110XS CSW TD5. |
27th Mar 2018 4:21pm |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2947 |
This ones really fast
Click image to enlarge |
27th Mar 2018 4:38pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1767 |
Makita do an 18V powered one!
27th Mar 2018 4:51pm |
Fort wheelbarrows are very popular here. Here’s a picture of mine now at 15 years old, living summer and winter out in the open, not really sheltered, often abused. It surely has another 15 years of life in it. Not even expensive.
Eric Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
27th Mar 2018 4:58pm |
