Home > Puma (Tdci) > “Clang” when stumping hard on the brake pedal |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8145 |
rattly brake pads? Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
26th Mar 2018 11:28am |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 549 |
Would rattly brake pads cause such a noise even when the wheels aren't spinning? “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
-- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
27th Mar 2018 9:30am |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 733 |
Just guessing here, but when you actuate the brakes with the engine off you release the residual vacuum from the servo. Could it be the springs in the servo rebounding when you release the pedal?
27th Mar 2018 12:05pm |
srod Member Since: 20 Mar 2015 Location: Argyll Posts: 190 |
Yep anything involving brakes and abnormal behavoir is worth worrying about...
Can you have a closer listen, get someone to press the pedal while you go round all four corners try and find out exactly where it's coming from? |
27th Mar 2018 7:05pm |
yes, actuation of brake pedal pushes pistons out which pushes pad to contact disc irrespective of whether disc is moving or not. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
27th Mar 2018 8:03pm |
Sounds (and feels) like a spring, seems to be coming close to the pedal itself, possibly from the servo, but not sure... I don't think this is remaining vacuum in the servo because it happens every time, just just once. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
28th Mar 2018 8:38am |
the spring that returns the pedal hasnt broken one arm has it? Cheers
28th Mar 2018 7:24pm |
