![]() | Home > Tdi > 300 or HS 2.8 |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8172 ![]() ![]() ![]() |
i know of a 2.8 available if thats what you decide on Cheers
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10891 ![]() ![]() |
^^^ Many thanks JST i will take you up on that once i know which way i will go
![]() Is it up for sale publicly or a private sale ? many thanks again ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
as far as i am aware its not advertised. Cheers
This popped up in my random searches on eBay,
https://rover.ebay.com/rover/0/0/0?mpre=ht...3068423187 Nothing to do with me, wouldn’t be selling if it was ![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
ppad Member Since: 16 Nov 2012 Location: now, UK S Coast Posts: 223 ![]() ![]() ![]() |
![]() Click image to enlarge We put a 2.8 into this almost 10 years ago now and when I was back in Oz in Nov drove it again, it pulled amazingly, probably better than my 05 90. Put good Disco brake server in to stop it, and good radiator. And Disco gear ratios. Given all that, it'll go forever. It did drive, or say on the water gauge, that it was hot for the first few thousand km, then it settled down and pulls like the proverbial. Great engine. Sold the much modified 110 2.8, in Oz Brought the 90 home from Switzerland ... |
i run Disco servos too on off roaders, and autos on Defenders, they are much better for repeated heavy braking over the std tdi ones. Cheers
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6133 ![]() ![]() ![]() |
How easy is it to fit a disco brake servo? do you change the master cylinder as well?
Hi Jamie, its simple to change from a nut and bot job, just fiddly doing the clevis pin on the brake pedal.
on my '84 the master cylinder fitted to the Disco Servo, on my '92 it didint and i used both disco servo and m/cylinder bearmach do a replacement servo that is std part number for defender but is actually a fair bit deeper that takes the std def m/cylinder. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Thanks James
Is that a disco1 or 2 servo? |
disco 1, 300tdi with ABS Cheers
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
Is there any advantage to fitting one to a Td5 defender? I assume there is more servo assistance? 2002 90 Td5 Station Wagon
dont know specifically on a td5 as never done it.
there is no greater assistance just more air (well less - greater vacuum) held in the largr res which means you have servo assistance for a great period. not normally needed on a non ABS vehicle but i was running an auto and off road you use the brakes a fair bit on very steep descents, cadence breaking eats servo power so the greater the vacuum capacity of the servo the better. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
