Home > Technical > Crabbing
Chamois
2002 Defender 110 Td5 CSW Zambezi Silver
Crabbing
Hello all
My 02 TD5 seems to be crabbing a bit to the left, It's not been in an accident and I can't see anything that out of sorts. Measured control arms and all seems ok.
Rear shock top bushes are shot but that's about it.
Anyone have any advice on what might be the biggest culprit assuming it's not the chassis.
A frame looks ok although it's hard to see the bushes so not entirely sure of there condition.
Thanks heaps Winter's here, thanks goodness!
Post #694844 20th Mar 2018 8:19am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
As a first step, it might be worth making a quick geometry check, just park up on a level surface and make a chalk mark on the ground at the centre of each wheel, then move the car and measure the distances diagonally.
I don't know what the tolerance is but it might at least give you a clue where to look further.
Post #694869 20th Mar 2018 9:28am
ibexman
Get another person to follow you to confirm you wouldn’t notice much from driving seat
Post #694901 20th Mar 2018 10:56am
I once worked on a brand new Rangey (L322), belonged to a company that sells very expensive Defenders...
It needed an airbag sensor, which is buried down under the centre console, which meant it had a crash at some point.
Out of curiosity we measured the wheelbase, it was only 2.5 inches shorter on one side!!!
Post #694907 20th Mar 2018 11:30am
geobloke
Have you lifted your Defender? If so and this is esspecially the case in bigger lifts, it can cause crabbing as it pulls the front axle out of alignment with the rear axle. The culprit is the panhard rod being too short. Solved by fitting an extendable version.
If not lifted then I would be looking at the bushes, especially the radius arm and pan hard rod bushes. Slop in these can also cause the axles to shiuft out of alignement.
Post #694920 20th Mar 2018 12:53pm
