Home > Wheels & Tyres > Best wheel carrier for 1999 SW?
Loz2286
Mantec, Britpart, Swingaway????
Any thoughts???
Thanks. 1999 Td5 110 CSW
1961 Series 2 88 LPG
Post #693744 16th Mar 2018 11:47am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Mantec !
Thumbs Up Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #693747 16th Mar 2018 11:56am
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
I’ve got the mantec too. Although technically fine it has been developing those red brown spots rather quickly.
On this forum a lot of members fancy the Nakatanenga one. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #693756 16th Mar 2018 12:15pm
familymad
Mantec is good but I didn't want to drill out any painted vehicle rivets to fit.
Naka is enlarging some x member bolts and you are good to go. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #693766 16th Mar 2018 1:13pm
leeds
Mantec ceased trading in November 2017?
Best wheel carrier? Have a read of this
Brendan
Post #694171 17th Mar 2018 9:19pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Re: Best wheel carrier for 1999 SW?
Any thoughts???
Thanks.
I've been looking myself and came up with a few options,
The Nakatanenga one looks popular https://www.nakatanenga.de/en/optional-equ...w/ht?c=325
Pricey at £550 delivered direct from Nakatanenga
Ebay has an original kit https://www.ebay.co.uk/i/272886467878?chn=...amp;crdt=0 much cheaper at £169.99 although you will require a seperate kit to mount an alloy. Check year to make sure it fits yours.
Paddocks do one for £134.53 http://www.paddockspares.com/pm132-rear-do...NgQAvD_BwE
Have a look around and you'll find one, they all do the same job Very Happy
Post #694185 17th Mar 2018 10:36pm
Blacksheep
Another option:-
Does anyone have any experience of the Masai swing away wheel carrier, I notice that it's galvanised prior to painting.
Not sure about the heavy duty and extra heavy duty? Time is precious, waste it wisely...
Defender 90 D200
Post #694219 18th Mar 2018 7:59am
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
Blacksheep, I have the Masai although my only experience of it is providing a bit of space for it in my garage. Nothing wrong with it, it’s just one of those jobs I haven’t yet got round to.
The difference between HD and extra HD is an additional brace across the frame.
Post #694225 18th Mar 2018 8:08am
Zed
Decent hinges?
Post #694241 18th Mar 2018 8:50am
rockster57
The Masai hinges look well engineered and each is factory fitted with grease nipples. If anyone’s interested, I shall shortly be listing my Masai for sale.
Post #694254 18th Mar 2018 9:17am
Blacksheep
Rockster57, I'm interested.
Sent you a pm Time is precious, waste it wisely...
Defender 90 D200
Post #694262 18th Mar 2018 9:33am
leeds
The Nakatanenga wheel carrier is stainless steel and only require 2 holes in rear cross member opening up from 8mm to 10mm. They make one of the widest ranges of wheel carriers.
Safari Equip do a single pivot wheel carrier, mild steel, requires some holes in rear cross member opening up to about 13mm. They also do 'standard' wheel carriers which require the body work drilling and have grease nipples at the pivot points. All their range of wheel carriers are mild steel and we can supply them in different finishes including powder coated, galvanised or galvanised and powder coated.
Brendan
Post #694350 18th Mar 2018 1:39pm
Blacksheep
Masai carrier fitted today, many thanks to Peter (Rockster57)
Well engineered imho
Defender 90 D200
Post #695467 22nd Mar 2018 6:13pm
