![]() | Home > Technical > Heater starts alarm |
Lowe Member Since: 13 Nov 2017 Location: Frederikssund Posts: 37 ![]() ![]() ![]() |
My "new" defender has a webasto diesel pre heater.
When using the heater the car alarm starts after app. 15 minutes The voltage at the time is 11.91v and the blower is running. Has anyone had this and is there a cure |
Today i changed the battery to a brand new one fully chargede.
Started the heater, and 10 minuts later the alarm went of. So what can it the bee.. Can the alarm be disarmed with my nanocom ? |
Heat waves setting off the internal sensor?
Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 618 ![]() ![]() |
Tape over the ultrasonic sensors and try it. V8 90...WIP
I might be getting mixed up between vehicles but I thought there's an alarm/lock option that disables the interior alarm - for when you want to leave a child/pet inside?
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 ![]() ![]() ![]() |
If you lock the car by the key in the door it arms the perimetric alarm and not the volumetric internal alarm so should disable the internal sensor but keep the doors and bonnet protected.
Thanks, now i have some more to go on..
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8171 ![]() ![]() ![]() |
my webasto heater air flow set the car alarm off in my '99 td5. i just pulled the wires on the volumatric alarm. locking by key didnt disable on that one. Cheers
To be fair, I think jst got you there 1st time:
Solved..
Pulled the plug from the volumetric sensor and now we can heat up without waking up the neighbors.. |
I guess the next question should be whether the sensor can be moved, the sensitivity of the OEM one adjusted or can be swapped out for one that mirrors the dual tech ones you get for conservatories?
My RRS had the pre heat facility and never set the interior alarm off so maybe the electronics disable the sensor on start up or it's a different type of sensor? |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 ![]() ![]() ![]() |
Perhaps a cut out relay that cuts the wire to the volumetric when the heater or fan is running?
Suits me fine that the sensor is disconnected, then it dosnĀ“t start the alarm if the dog moves around.
