Home > Series Land Rovers > Which Series 2 Headlamps?
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Hi there,
I have a series 2 headlamp panel (as below) but missing the lights (pic off google), and am trying to get my head around which type of lamps can be fitted.
I've seen some series 2's with flush headlamps, and some which protrude with a chrome ring.
Which type do I fit to this panel? Assume flush as per pic.
Or can either type be fitted?
And depending on the answers, know where I can purchase the correct kit from?
Thanks in advance.
 Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #693507 15th Mar 2018 11:22am
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
If exactly as the one in the picture It is a Series IIA panel. There are Chrome rings around the headlamps but they are mounted behind the break fast. The three screws on the panel are the securing and adjusting screws. They have a spring behind them to adjust the lamp.
The Series II used a headlamp mounted in front of the break fast with an additional chrome ring finisher. This was I think a common Lucas set up on many cars of the sixties.
Early one has more parts but has more shiny chrome. It is easier to fit old style beam converters to them.
The later IIA ones are a bit easier to set up.
On the headlamps themselves don't use the original feeble sealed beam units. Get Wipac or similar halogen bulb conversion units. Light onto the road is quite poor as headlights are in centre of car and wings shield a lot of the light.
There are also FV military headlamps which are much more expensive and even worse for light performance as fitted to my Lightweight and others. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #693567 15th Mar 2018 6:47pm
L90Andy
Fantastic reply, thanks!
Yeah mine is identical to the one in the picture, with the three small holes around the recess.
Would this be the right kit to fit?
https://rover.ebay.com/rover/0/0/0?mpre=ht...2332615365
There is a small chrome surround that may just show around the headlamp?
Thanks Instagram: L90andy
Post #693574 15th Mar 2018 7:06pm
Ramsay
The plastic ones should fit. I have not used them on a IIA so am not clear on the adjustment.
These
https://www.ebay.co.uk/itm/Land-Rover-Seri...0009.m1982
Seem to include all the springs and screws I would expect and the tails for connecting into the loom. 1995 Defender 110 CSW
Post #693581 15th Mar 2018 7:23pm
L90Andy
Great, thanks Ramsey Thumbs Up Instagram: L90andy
Post #693604 15th Mar 2018 8:37pm
22900013A
The changeover was actually on the IIA after a year or so of production. Series IIA chassis suffix A kept the bulging type headlamps. Suffix B and onwards had the flatter type, which are also mounted slightly lower on the panel. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #694244 18th Mar 2018 9:56am
