Home > Puma (Tdci) > Puma 110 rear sliding windows position. |
sewin elwy Member Since: 08 Aug 2012 Location: Snowdonia Posts: 39 |
Right now bender<
Visit the masai site, they have a selection. 2007 windows are different in size to earlier ones although I think they may have been introduced with new radius sizes slightly earlier than 2007. if you want a traditional look make sure you buy the riveted in type with the rubber filler strip. the puma ones are bonded in and you cant service them when the channel/rubbers and felt need replacing they are also a pig to fit with spacer blocks and to remove..... well even worse! or go for the safari panoramic full glass option for ultimate security and water resistance and a cool look. one last option, if its trad you want consider the fixed glass option as no service is required. Ask yourself this..... do you ever open them, not many do! |
14th Mar 2018 4:09pm |
Bender Member Since: 02 Jul 2014 Location: Ghaxaq Posts: 3 |
Hi thank you for the info. Actually as you said I will go for the TD5 type with the different radius but still have the rivets. I intend to modify them and turn them into gullwings which will enable me to access the fridge from the side. I will take a look at the Masaai Site.
15th Mar 2018 2:52pm |
Hi Bender
HAh Ah! not sure where but I've seen glass trad looking gull wing type opening windows, could well be Masaai! |
15th Mar 2018 3:21pm |
