Home > Maintenance & Modifications > Brake Pedal Squeak Fixed |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6613 |
Simple fix to this one, haven't seen in mentioned before.
Probably only applies to 15+16 model year Defenders with DSC. The two brake switch plungers (orange arrows) rub on the striker plates (green arrows) as you start to press the pedal. Click image to enlarge Just smear a tiny bit of grease on the striker plates to stop the plungers squeaking You don't even need to remove the plastic brake switch cover 1988 90 Td5 NAS soft top 2015 D90 XS SW Last edited by Martin on 14th Mar 2018 4:24pm. Edited 1 time in total |
14th Mar 2018 1:31pm |
cartoonhead Member Since: 02 Mar 2018 Location: Bucks Posts: 135 |
Thanks I’ve been meaning to sort this out for a while! Pic isn’t loading for me.
14th Mar 2018 4:22pm |
Fat Cog Member Since: 19 Mar 2012 Location: Oxfordshire & Devon Posts: 502 |
Unnecessary quote removed
Brilliant! My 2016 2.2 is squeaky & getting on my nerves...thanks! Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains |
14th Mar 2018 6:22pm |
