Home > Maintenance & Modifications > Best roof rack for 110 xs
sjc501
Newbie here Looking for recommendations for best roof rack for my 100 it will be used to carry bikes /surfboards and of course work stuff /building materials . Thanks
Post #693234 14th Mar 2018 12:21pm
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
Hello,
I have one of the Flat dog Rax with luggage rail. We regularly use it for transporting kayaks and bikes etc as the grooves in the slats allow you to mount various accessories and eye bolts and then quickly take them back out when you're finished. Its pretty similar to the Thule T-track system. It's aluminium and relatively lightweight (took 3 of us to lift and fit on my 110.
Happy shopping. Keith
Post #693240 14th Mar 2018 12:51pm
sjc501
Thanks Keith how much are they ?
Post #693249 14th Mar 2018 1:26pm
Keith5
Here's a link to the 110 Rax; https://flatdoguk.com/defender-110---rax~969
Just be careful when you look at accessories as it starts to get expensive Keith
Post #693252 14th Mar 2018 1:46pm
sjc501
I hear you . Smile
Post #693255 14th Mar 2018 1:48pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I have a Hannibal and very happy with it. It's lightweight but seems strong being a one piece construction and without the side rails it's low profile so I can still fit into car parks. Like the offerings from Flatdog, Front Runner etc it has slots in the horizontal bars and the outer edge to allow accessories and tie down eyes to be fitted / moved. The full-length mounts spread the weight along the length of the gutter rather than concentrating pressure on small feet like some types.
My only complaint is the powdercoating isn't great and has started to lift in places, but I've no idea how old it is, it was on the vehicle when I bought it.
 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #693258 14th Mar 2018 1:57pm
sjc501
Looks good also .
Post #693260 14th Mar 2018 2:00pm
sjc501
Cant seem to find black Hannibal roof racks for 110
Post #701410 16th Apr 2018 11:42pm
leeds
Looking for the BEST roof rack for your 110?
That is a very subjective question as people tend to recommend what they have.
If you want the best then I would suggest you have a good look at the Cargo bear roof rack system by Nakatanenga.
A truly modular aluminium roof rack system. Can start with a couple of roof bars and build it up to a 90, 110 or 130 roof rack. Can even get it to follow the slope at the front of the Defender roof. Standard tread plates or high grip tread plates. At just 60 mm above the roofline probably the lowest one.
Not the cheapest roof rack but probably the best.
Yes have used a Brownchurch style roof extending over bonnet, a Patriot rack, Rhino bars in the past.
Brendan
Post #701411 16th Apr 2018 11:56pm
Another vote for hannibal racks, I’ve had a mk1 and mk2. Mk2 came with an integrated picnic table the only reason I changed.
If I were to buy again, I’d get a flat dog simply because the slate are left/right rather than front/rear and make fitting a hard shell tent much easier
Post #701423 17th Apr 2018 5:57am
AMBxx
Other things to worry about - many car parks have height restrictors, so you may want to be able to easily remove for day to day use. I just have roof bars, I can fit and remove on my own.
If you have bikes on the roof, height restrictors are an even bigger problem. If I wanted to take a bike, I'd stick it on the spare wheel or in the back.
Building materials on the roof? Unless you're popeye or just thinking about timber/pipes, I'd think of a trailer instead.
One point above I strongly agree with - get somthing modular.
Post #701439 17th Apr 2018 8:21am
leeds
The Nakatanenga Cargo Bear is only 60 mm above the roof line so is one of the lowest roof rack going. The only lower one I am aware of is the roof rack from Arbenteuer 4x4.
Putting roof tents on and off unless you have some form of hoist/forklift can be awkward. Either access to nuts is restricted meaning take roof rack off or plenty of access which means high roof rack which has its disadvantages.
Nakatanenga do a roof tent mounting system which allows access so that the roof tent can be lifted off without removing a relatively low roof rack.
Brendan
Post #701457 17th Apr 2018 10:19am
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Haven't seen the Nakatanenga rack in the flesh, but I'll bet it's amazing.
I have the Hannibal, and have been very happy with it. I'm a fan of the mounting set up as it travels the length of the gutter, not just where the feet come to the gutter. Low profile, not really any noticeable wind noise (well, I have no center box on the exhaust Laughing). I do agree with a previous post though, the powder coating isn't the best I have seen, but it's better than most.
 it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #701542 17th Apr 2018 7:06pm
Greadh
United Kingdom 2013 Defender 110 Puma 2.2 USW Santorini Black
Roof bars are easy to fit/remove and store if needed, also a lot cheaper - but looks department they are left lacking. Personally I was disappointed when looking at a Cargo Bear few weeks ago when out with fellow land rovers, to see they had to fit standard roof bars to the Cargo Bear to be able to use standard fit items like a roof box Shocked I'd stick to a rack or bars allowing T Track items to be used.
Post #701556 17th Apr 2018 7:57pm
pesto_trader
Norway 2005 Defender 90 Td5 SW Tonga Green
My old car had a safety divices rack Thumbs Up
Post #701613 17th Apr 2018 10:49pm
