Home > Td5 > power loss for split second while driving at 60mph
993porky
United Kingdom 2002 Defender 90 Td5 HT Baltic Blue
hi im a newbie here,
i own a 2000 td5 90 hardtop,i have a strange problem which is when i drive on motorway for approx 15 miles onwards at near 60mph all of a sudden for a split second i lose power and the temp gauge shoots up into red but immediatly returns to normal and power is back then a few moments later the same,the engine never dies just loss of power for which can only be for half a second if that. however if i do same journey but dont exceed 55mph i dont get this problem.
also i can drive all day long at 30 mph and the problem never happens.
just done a 160 mile round trip greenlaning and never had prob until i hit the motorway on way home.
i have owned the landy for 3 years and had the oil in ecu problem when i first bought and had this problem fixed at garage.
this problem i have is really bugging me any advice would be great cheers. Big Cry
Post #69287 1st May 2011 11:55pm
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
If the temp gauge is doing that you could have damaged the sensor, if the sensor sent back a really high reading the ecu would probably cut engine power... Kinda like a safeguard. Hope this helps
Jack
Post #69288 2nd May 2011 12:03am
993porky
Hi landie boy thanks for reply, so do u think it cud b a temp sensor just broken and every now and then this prob happens due to dodgy sensor, also where on engine wud I locate this sensor so I can try a new one, also the loss in power seems to happen before the gauge moves.? Cheers for help
Post #69294 2nd May 2011 8:46am
Landie Boy
I'm not sure where it is in the engine bay, it might be worth you paying someone a visit who has access to diagnostic equipment. Any dealer has it, i reckon it will have created a error code which would be stored on the ECU. The dial will have a slower reaction time compared to the ECU...
Hope this helps
Jack
Post #69310 2nd May 2011 10:49am
Steve in Germany
Wales 2000 Defender 90 Td5 CSW Alveston Red
Next time your out, when you loose power watch your left hand mirror to see if you get any black exhaust smoke at the same time as the power lose. Def need to get it on diagnostics, I would bet on airflow fault.
Post #69323 2nd May 2011 12:22pm
Alive Tuning
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Havana
I do wonder if your head gasket is showing signs of age, and you're getting bubbles of hot exhaust gasses working their way up to the top hose? This will most deffinetly cause this to occur, and as previously said, the engine management has a strategey to reduce engine torque when there are excessive coolant temperatures.
The fact this only occurs under relatively high loads, and prolonged use, would reinforce my theory. Engine load increases exponentially in relation to wind resistance, and at around 50mph your engine is at the threshold of peak efficiency, and so will return best mpg in 5th. As a simplified example, To maintain a constant 60mph would take an additional 20% more effort from the engine, 70mph would be 40%, and so on. It's this extra loading which would be enough to raise cylinder pressures enough to breach the seal on the head gasket, and introduce gasses into the cooling system. Most of the gasses will be vented to atmosphere in the header tank (degassing tank), hence why you're not seeing overpressurisation of your cooling system, and hence blown hoses.
The engine temp sensor is located where the top coolant hose meets the head, on the exhaust side of the engine. The chances of this sensor being faulty, I expect would be very slim.
The wiring in that area is exposed to some pretty extreme temps, and it is possible that the wires to the sensor may not be 100%. A quick wiggle test would prove this I am sure, but if the circuit failed, the temp gauge would drop rather than rise.
Post #69327 2nd May 2011 12:46pm
993porky
Hi thanks for the replies some useful thoughts for me to look into,if it is head gasket is that a case of getting it repaired asap to avoid further damage.I have got a secondhand sensor I might put in just incase.also keen to get the vehicle chipped for better performance, was going to make enquiries at landy show next week at Driffield,are you at the show got a few engine upgrades I'm interested in thanks.
Post #69344 2nd May 2011 3:06pm
Alive Tuning
993porky wrote:
if it is head gasket is that a case of getting it repaired asap to avoid further damage..
Yes, deffinetly! Blown Head gasket symptoms on a Td5 are usually different to most other cars, as it usually shows itself in the form of overpressurising the cooling system.
First thing to check is the presence of air in the top hose. Squeeze the hose repeatedly, and feel if it has coolant in there. You should see a spurt of coolant going back into the expansion tank, and should generally hear it sloshing around. If it feels empty, undo the bleed screw carefully and bleed the system. If there is plenty of air in their, you've got to ask why?
With the engine cold, undo the expansion tank filler cap, to release any positive pressure held in the cooling system. Refit the cap nice and tight, then drive the car as normal, to get it hot. Ideally, it would need a bit of a spanking to ensure you're seeing high cylinder pressures, to breach the gasket, so once up to temp, give it some, but keep an eye on the temp gauge so as not to cook the engine! Allow the car to cool (overnight perhaps), and then open the expansion tank cap again. Is there a woosh of high pressure being released? Anything more than a breif low pressure replease is not good. Also check the top hose again for air?
993porky wrote:
I have got a secondhand sensor I might put in just incase..
You can try it, but I doubt it'll cure it. Remember to bleed the system up after fitment.
We'll be there in our usual place, next to the green toilet block! Rolling Eyes PM with the parts you'd like, and I'll ensure I've got the parts for you, with forum prices too. Thumbs Up
Post #69360 2nd May 2011 5:29pm
vulcanfreak
2006 Defender 90 Td5 Silver LE Zambezi Silver
just my tuppence worth
if the impact sensor on the bulkhead is faulty or bad connection this will cut power instantly AND the temp guage will go straight into the red
Kev
Post #69390 2nd May 2011 7:20pm
Alive Tuning
Kev
But if this happened, the engine management would cut the engine, and the hazards would flash.
Post #69393 2nd May 2011 7:32pm
DBMG
United Kingdom 1999 Defender 90 Td5 HT Epsom Green
Found this on another forum:
"Td5 Not Starting/Intermittent Cut-Out
The information below was supplied by Saif Al-Noaimi.
Recently I ran into a problem with my 2001 Defender 90 Td5 not starting and intermittently dying on me on the highway.
I sent the car to the dealer 4 times and first 3 times they were clueless. The 4th time they replaced the ECU wiring harness because they feared it was the oil in the ECU problem. Thankfully the car was still under warranty. But 2 months after that was done (car is now out of warranty) it died on me again.
I posted in the Land Rover Addicts Forum my problem and amazingly it turned out to be the relays under my passenger seat were just loose! Apparently they are saying this is a common problem so I thought it might be useful to others to include it in the KB.
Post #83036 3rd Aug 2011 10:15pm
AndrewS
I reckon its
The maf air flow sensor located on the intake side of the air filter box. Easy fix.
The sensor gives a false reading that fooks the intake air flow that then results in increased engine temp. 130's have feeling's as well you know Smile
Post #83038 3rd Aug 2011 10:25pm
landy andy
I have had this on mine, but only when pushed hard, very hard, after hours of motorway @ 75mph, then up big hills on motorways in spain @ 35 degrees.
It is not an over heat issue, the reactions that needle makes are sudden, and not progressive, you can turn engine off back on during the low power and get the power straight back.
The harder you push the more you get it. Back off a bit and it is ok.
I later after experiencing it had my exhaust manifold warp (it was warped during this problem, but unnoticed) pulling studs from cylinder head. I have removed cleaned, all relays under drivers seat, run an extra earth to ecu panel.
Since doing these I have not had the problem return.
Having dealt with Gary @ Alive recently, he did say that the remap that I had would give me VERY high exhaust gas temps, so he remapped.
I do think that is a sensor failing possibly due to the exhaust manifold allowing very hot gases out, when it was warped.
Andy
Post #83048 4th Aug 2011 6:44am
Laurie
Happens to me occasionally when towing the caravan.
Post #83058 4th Aug 2011 8:14am
wslr
I've seen it with the main wiring to the engine ECU under the seat. Sometimes it is pulled tight and gets damaged internally.
Leave the car running at idle and fiddle with the wires under the seat. Moving them may cause the vehicle to stop running or misfire for a moment.
Post #89761 18th Sep 2011 10:48am
