Home > In Car Electronics > Exmoor trim heated seat kit
excossack
Just ordered the Exmoor trim kit (pads and loom)
For those who have installed did you;
1) wire direct to battery/12v source and make sure the seats are off before you leave the car
2) wire via a relay that is only active when engine running/ignition on (maybe via radio/rear heated screen feed?) and used that to feed the two main relays?
3) other? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #692889 12th Mar 2018 7:26pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
I wired mine into a "bluesea" style split fuse block.
One side is permanently connected to my 2nd battery and the other side is energised via an ignition switched relay (switched positive courtesey of some caravan electrics).
The heated seats are on the ignition switched side, I can keep them on as long as the ignition is turned onto the "accessory" position but you can't leave them on if you take the keys out of the ignition.
It seems to work for me. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #692892 12th Mar 2018 7:32pm
dgardel
Italy
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #692978 13th Mar 2018 12:12am
excossack
What year did the wiring come in from LR for heated seats? Mine is a 1999 td5.
If i do have the wires its time to go hunting. 1999 Defender TD5 110
Regards
John M0VAZ
Post #692997 13th Mar 2018 8:05am
t was probably the TD5 facelift in 2002. Darren
Post #693020 13th Mar 2018 9:53am
excossack
Cheers LRA - didnt think there was wiring in place.
I did have a thought.....i was thinking that if I used a Voltage sensing relay so the heated seats only work at say 14v then i could use the relay to power the heateed seat loom, the heated mirror kit that I also have to fit and finally kick in the split charge relay (which is fed via trip coming from the radio.) 1999 Defender TD5 110
Regards
John M0VAZ
Post #693546 15th Mar 2018 5:07pm
excossack
Got the loom installed. Just enough room under a standard cubby box to put the relays and the wires.
Each loom has 7.5amp fuse so wired both looms together and feed the pair of looms via 27amp cables fed from an 80amp relay that is only active once the engine reaches 14v. (switched by a separate module).
I will use the same relay to feed the heated mirror elements when I get around to installing them
All I need now is a parcel from Exmoor trim. 1999 Defender TD5 110
Regards
John M0VAZ
Post #697274 30th Mar 2018 7:41pm
excossack
Parcel from Exmoor arrived yesterday containing the seat trim kit Smile
Fun will commence when I get a spare weekend 1999 Defender TD5 110
Regards
John M0VAZ
Post #701838 19th Apr 2018 1:57pm
