Home > Technical > Headlights... off, then, then on again |
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 |
I had a similar problem with my 2010 110 just before Xmas, switched on headlights, no joy, sidelights worked ok. Did the usual, stripped the column down checked the fuses, switches, wiring, connections, no visible problem, put it back together, it worked - for a time, so bought a new main switch, swapped it over, didn’t work! Put the old one back, it worked for a time so next time it happened, a few days later, I ordered a new dip/indicator switch. Started working again before I put in the new switch so being a great believer in “don’t fix it if it ain’t broke” I left it and, touch wood, it’s been fine! and I now have 2 spare switches.
So, in short (no pun intended) I never did get to the bottom of it! I think mine’s down to the Defender gremlins. In the meantime I’ve fitted a boomslanger loom which should take the stress off the system. Sorry I can’t narrow it down for you but I think the general consensus will be that it is the main light switch which takes the full current to the headlights, about 10A with halogens but probably less for LEDs. There’s no relay unless you’ve upgraded your loom. 2010 Defender 110 Station Wagon, Santorini Black. |
12th Mar 2018 11:52am |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 |
Thanks, the strange thing is, it never stays off... always comes back, after a few mins, or a few times on the main light switch, turn off / on.... it fires back up.... might change the light switch, cheapest option and see if the problem comes back.
12th Mar 2018 12:03pm |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 |
Indeed the main switch is a weak point. It's always a good idea to keep the load of the switch.
But since you have all led I guess this isn't the case. It sounds like an earthing and or loom problem to me. I had it also and a previous had been tinkering with the loom and had all sorts of light problems. a defender from 1984 pretending to be a puma with a touch of Range Rover |
12th Mar 2018 12:20pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20504 |
Try adding a temporary Earth path to the headlight loom, easily done and see if there is any difference.
If not, only 5 mins work to try. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
12th Mar 2018 12:24pm |
I think that’s the right thing to do, you can get an OEM one for less than £20, not too expensive in the scheme of things! 2010 Defender 110 Station Wagon, Santorini Black. |
12th Mar 2018 12:35pm |
