Home > Series Land Rovers > Series 1 88” rebuild
Page 4 of 4 <1234
Zed
Lovely work. Congrats.
Post #692053 8th Mar 2018 8:04pm
Ellisboy
1998 Defender 90 300 Tdi CSW Epsom Green
Looking good Andrew Bow down
Stephen.
Post #692062 8th Mar 2018 8:43pm
L110CDL
Nice one Thumbs Up
Ian, you should go, nice little convoy of series 1s Whistle 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #692068 8th Mar 2018 9:10pm
gcc130
Thanks all, it's good to have it back up and running.
Ian, you'd be more than welcome. I know it's will be quite a run from yours but there should be a good turnout.
Post #692072 8th Mar 2018 9:30pm
gcc130
It a while since I’ve updated this thread.
We made it to the pub meet at Priddy without incident, though a heavy snow shower made the first hour of the journey quite interesting. Once up onto the top of the Mendips the snow stopped but the wind was v cold.
I need to adjust the clutch to bite a bit higher, although the brakes are good l need to bleed again or adjust to reduce travel on the pedal and I need to rethink the accelerator pedal arrangement, it’s too light and I’m not achieving full throttle.
I think the sound deadening is an improvement, and it certainly reduces the heat coming through the bulkhead, mind you so does the fact that there are no holes in the bulkhead now😊
The old bulkhead, chassis and tilt have all gone to new homes which helps the rebuild funds and I’m very pleased with the new Undercover Cover’s tilt.
I’ve now decided I will do some cosmetic tidying before we use it for my daughters wedding in June, I’ll keep you posted.
Post #696149 25th Mar 2018 10:15pm
gcc130
Post #696150 25th Mar 2018 10:16pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Looks great Andrew,
I didn’t realise Priddy Went ahead!
Thought the weather put pay to that? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #696170 26th Mar 2018 6:13am
gcc130
Ian,
The original date of 3rdMarch was snowed off but we postponed it to the 17th.
It was I bitterly cold up there so not much time spent looking at vehicles in the car park!
Andrew
Post #696172 26th Mar 2018 6:19am
gcc130
Making the most of the good weather I made a start on the cosmetic work.
So far prepared the front wings and bonnet and sprayed with etch primer.
Need to get some hi build primer on on it to cover lots of fine scratches before top coating.
I’m not aiming for a perfect finish, just presentable for the wedding in June.
Post #702224 21st Apr 2018 8:00pm
Ellisboy
Nice job Andrew Thumbs Up
Stephen.
Post #702277 22nd Apr 2018 7:02am
JOW240725
Great work! Thumbs Up James
Instagram @suffolk_rovers
Post #702303 22nd Apr 2018 8:27am
Page 4 of 4 <1234
