Home > Td5 > Demisting Upgrade |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
I'm aware of the kits that involve removing the dash and inserting additional vents into the ends to demist the side windows, but has anyone here fitted these surface mount alternatives? Are they any good? How do they look once fitted?
http://defenderupgrades.co.uk/product/defender-demister-set-2/ |
6th Mar 2018 2:06pm |
Good info - thanks. Are you able to share a photo?
6th Mar 2018 4:08pm |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1364 |
The MUD Uk kit is better in my opinion
6th Mar 2018 4:25pm |
6th Mar 2018 4:30pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4786 |
The adjustable lower vents that I do if pointed in the right direction will demist the side windows
http://www.defender2.net/forum/topic59006.html 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
6th Mar 2018 5:29pm |
These are both flawed, but they are also better than the standard setup.
I went for the Mudstuff version in the end. Bit of a fiddle to fit, but works well once the heater has warmed up. Always thought that the being able to re-circulate the warmer inside air would make an awesome modification... But how...!?! At one point X-Eng were looking at fitting an electric element to the heating system to speed up the process of de-misting, but I do not know how far he got. |
6th Mar 2018 5:44pm |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
Have a look at this thread http://www.defender2.net/forum/topic33126-15.html
I've toyed with that idea, but 1kw of heating would be required which combined with headlights and other stuff would exceed the alternator output or put it under strain inevitability causing it to fail prematurely. A second alternator and mounting kit is £200 plus another £50 for wires and heating elements which is more than a sleeve... Also remember, the hotter the inside of the car, the more the unheated windows will mist up. The only true way to demist is with a 20,000+ btu AirCon system |
6th Mar 2018 6:33pm |
Sadly not on an aircon equipped Td5. The aircon blower is good for circulating dry air, but it always cools. Maybe a simple modification to the switch wiring could allow the fans to run without engaging the compressor... Does anyone have the schematic handy? Last edited by Intercept on 7th Mar 2018 12:52pm. Edited 1 time in total |
7th Mar 2018 12:23pm |
I had a set of the dash-top demisters on my old TD5 and they were pretty good. Ultimately though, either them or the Mud solution are limited by the weedy heater fan. Darren
7th Mar 2018 12:36pm |
Ooo cheeky recirculating system plan... The aircon condenser on Miffy rotted away, so removed it last summer. I do mean to replace it but it is just not a priority. However adapting it to recirculate could be an interesting project. |
7th Mar 2018 12:57pm |
Correction: the Td5 aircon controls do allow the fan to be used without engaging the compressor. Obviously this won't dry the circulated air, but a 5 mile lunchbreak drive with the heater on max into the footwells saw the aircon vent air temperature hit 20C which was 5C higher than the cabin ambient. Hardly toasty, but the coolant temp gauge was still only just above the blue zone at the end of the test run.
Engaging the compressor will dry the air as well as cooling it, so might have some side-window demisting ability with the aircon vents aimed sideways. But the cabin would be very draughty and the wife would complain of frozen knees. Experiments continue... |
7th Mar 2018 2:38pm |
Dieseljock Member Since: 03 Jun 2017 Location: Inverclyde Posts: 31 |
Just bought a set of grafftys adjustable lower vents and they do a brilliant job of clearing the side windows
7th Mar 2018 7:33pm |
