Home > Puma (Tdci) > Temperature gauge
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Temperature gauge
What does our the temperature gauge on our TCDi’s actually tell us?
As the subject has come up recently a couple of times, I took some shots on the way home the other day, to put a number to the various positions of the needle on the scale. Mines a 2012 2.2 with about 55 t miles on the clock. The weather was (finally) a mild eight degrees above zero . I’m on back roads driving in moderate traffic.
38 degrees, needle hasn’t moved
43 degrees, and the needle has climbed
51 degrees, and it is on the lower mark
At 60 degrees it is a quarter up
At 71 degrees it is nearing halfway. The motor isn’t fully warmed up.
82 degrees is as far as I got on the gentle 20 minute journey. The motor is near it’s proper working temperature and the needle is just below the mid mark.
Hope this is of some interest. Will be good to do the same on a hot summer’s day to see how little the needle moves when the motor temperature gets up to 110 degrees under load.
Stephen 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTs,
Recaro CSs, anorak, wellingtons
Post #691447 6th Mar 2018 3:05pm
Stacey007
With my scangauge (same as yours)
The temperature on that reads between 88 and 92.
92 was on the trip from Calais to Annecy loaded up, AC on 75/80 mph hour after hour heading to the hiller parts near Annecy.
Its normally very stable at 88 /89 degrees. I tend to use the guage for revs' Speed, temperature as I find it easier to see also as the steering wheel cuts the view around 55 to 75 mph Smile
Post #691449 6th Mar 2018 3:14pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
After several temperature issues I'am convinced it is purely installed for esthetical reasons. I think it isn't even connected to any temperature sensor on the car. Whistle At the end of the design they just had a hole left Rolling with laughter
It just goes up after a few minutes to about halfway and then it stays there. Even if the coolant temp is 115 degrees C it won't move at all. But the car will go into limp mode (with of course no errors).
Therefore I always use my icarsoft (same as scanguage) to check. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #691450 6th Mar 2018 3:15pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Your 3rd photo reading just the same by the looks of it...
 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #691470 6th Mar 2018 4:25pm
zsd-puma
Many modern cars don't even come with a temperature gauge. But those that do all they've ever told you is "cold", "normal" and "too hot". There's no real accuracy to them beyond that.
Around 75-90 degrees is normal operating temperature on most cars, which will put the needle somewhere in the middle. Anything below that is cold and much above it is too hot.
On a Defender the thermostat opens at 88 degrees and cools the engine down. If it doesn't then the viscous coupling engages and the fan works hard to cool it further. On most modern cars the electric fan kicks in and does the same job.
Post #691529 6th Mar 2018 7:35pm
Wild Card 90
Thanks Ian, it would be interesting to get feedback from other TDCi owners to see if in fact the temperature is consistent.
We have already established that there is something written into the software that makes it stick at around the mid position until the temperature is already critical, and it is too late to react, but i do believe the low to mid needle positions can be relied on. 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #691559 6th Mar 2018 8:27pm
ian series 1
Slight OT^^^
Who’s alloy dial rings have you got in your instrument cluster?
Thumbs Up 80" 80" 86" 88" 90"
Post #691564 6th Mar 2018 8:39pm
Tdi4
No you really can’t rely on the gauge!
My car went many times in limp mode. And the gauge was in the middle.
But on the icarsoft i found temps over 110 degrees celcius.
So don’t rely on the gauge. It’s realy realy unreliable. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #691581 6th Mar 2018 8:56pm
Slightly OT, but I noticed when I changed my coolant that my temp gauge stayed just below middle afterwards.
Previously around half way.
I can only but assume the mix wasn't that good before, and some watered down coolant was used. Rolling Eyes (not by me).
It's been just below middle ever since the same as th pics here, and mines a 2.4 so it seems they run both about the same roughly 88.C although I only have the gauge to go by. No Guts, No Glory.
Post #691595 6th Mar 2018 9:33pm
Wild Card 90
The subject of going into limp mode has been covered elsewhere, but seems to be one of the very few issues that was improved on the 2.2. My 2,4 would occasionally give up, mid summer on an incline, with 3.5 tons on the hook. The 2.2 hasn´t.
I think showing pictures of what the needle does (subtle) as the temp climbs from 82 degrees up to 110 degrees (rare on mine) will be interesting.
@Ian
In a weak moment last year I ordered the dial and air vent bezels from Croytec. Wonderful quality, easy to fit. Well worthwhile.
Long since forgotten how expensive they were.
Your properly integrated Ultragauge looks brilliant. Very envious! 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #691641 7th Mar 2018 6:51am
