![]() | Home > Wheels & Tyres > Which tyre for Bowler 16's? |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2209 ![]() ![]() ![]() |
Ive got Cooper ST Maxx 285/75 on mine.
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3355 ![]() ![]() ![]() |
That looks great. Are the extended arches necessary or just for looks?
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 925 ![]() ![]() ![]() |
Having done a little
![]() Don't get me wrong the BFG at KO2 is a grand tyre and very popular but for me wanting just that bit more ALL in the all terrain and still have good life and road manners than the Cooper ticked a lot of boxes. and for 4 in 235/85 they were ovr £100 cheaper. ![]() Click image to enlarge Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
Cheers, they are needed. The tyres are pretty wide as is + 30mm spacers makes for quite a wide track! They sit just inside the arches. They are great on road, i had STPros before, the difference between the two is like night and day. |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7916 ![]() ![]() ![]() |
265x75R16 BFG KO2's. Very pleased with them in all conditions so far, very reassuring. Boringly good in snow
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Just a small collection, if you want more I have a few... hundred ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1886 ![]() ![]() |
Lovely JOW - I'd like a set and see those wheels quoted as being 7.5" wide on several sites, but Bowler say they are 8" and would hope that they know best, so I'm guessing 265's would be the preferred option as it feels to me that 235's would be a bit small on a rim that width? Rob
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
Cheers JOW. Looking good and nice to know they handle snow.
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 ![]() ![]() |
Assuming you want to keep the suspension and bodywork standard you have about 3 options on an 8” rim
255/85R16 - taller and a little wider than standard. Improves ground clearance, little more tyre of the ground. Really only 2 options for tyre in this size. BFG MT or Toyo open country mt 265/75R16 - Same diameter as the standard size, so same ground clearance. Wider than standard so more tyre on the ground for improved looks and potentially better grip. Many tyre options. 285/75R16 - wider and taller (about the same height as 255/85) But could give problems with the body work at big articulation. Likely to be the heaviest tyre of the 3 options so the suspension will be working harder. Quite a few options on this size. Bowler typically fit 265/75 in an AT pattern - this was also a size fitted from the factory at some point I believe. 2014 Keswick Utility 2.2 |
Thanks for the comprehensive answer. I'm leaning towards 265/75 based on your info and JOW's photos.
That's way I'd go
![]() 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4801 ![]() ![]() ![]() |
Very comprehensive and informative reply “ Utility Truck “
![]() 2008 SVX 90 2000 XS TD5 90 |
