Home > Td5 > Heater blower modification? |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 |
I'm thinking of doing so too. They also sell the demister vents that mudstuff do - but somewhat cheaper.
5th Dec 2013 9:09pm |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2402 |
my td5 is either off or full blast and I'm used to it and quite like it! if too hot i just open a window! if i want variable luxury I just use the disco 3 lol, 2008 Santorini Black 110 XS USW (Sold)
2015 Discovery 4.5 Black pack Firenze red XS 2008 Corris Grey 110 XS USW (sold) 2011 Santorini Black 110 XS USW (Sold) |
5th Dec 2013 11:04pm |
Hock Member Since: 12 Sep 2011 Location: Yorkshire Posts: 131 |
I concur, if it's cold stick the heater on, if you get warm take of your jacket, then your jumper then resort to flaps or window
Variable heating control on a defender is in my opinion not in tradition with the spirit of the vehicle haha |
5th Dec 2013 11:12pm |
Skye_Rover Member Since: 29 Aug 2013 Location: Skye Posts: 85 |
There's a rheostat switch on the older Rover cars as well; my P4 nearly caught fire after I found a "sweet spot" in its adjustment of the control that had the wire-wound track glowing cherry red after a few miles. Because you can reach under the dash on a P4, I was able to feel how hot the potentiometer had got - I still bear the scar on my left hand! I have a variable heating control on my TDi; heat output is great in the summer, but weakens as the winter approaches. Roads? Where we're going, we don't need roads. |
8th Dec 2013 12:54am |
Gareth Member Since: 12 Dec 2011 Location: Bramhall Posts: 1102 |
Closing off his thread, I did fit the Landrezieger heater kit and it's fantastic! Works really well with 100% proportional control over the fan. It makes it so much easier to get comfortable.
It's Easy to fit, ask for English instructions. The only thing I found was the box that mounts on the heater box fouls the bonnet, you need to mount it as low as possible, and on rhd cars the wires are tricky to get to down the side of the heater. It's been reliable except I blew the rheostat accidentally when fitting it to a metal dash pod replacement. A replacement was sent from Holland very quickly. It's a great modification. A 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
5th Oct 2017 8:56pm |
GSLRO Member Since: 13 May 2012 Location: Tyne and Wear Posts: 499 |
Cheers Gareth will get one ordered. Adventure isn't paved!
5th Oct 2017 9:01pm |
well done Gareth. any photos of the install?
6th Oct 2017 6:25am |
Coatesyyy Member Since: 07 Sep 2017 Location: Knutsford Posts: 423 |
Would be interested in seeing some photos too please
7th Oct 2017 7:57am |
Have to add the best thing i have done to the heating system in Miffy is to give it a darned good service. Big flush, new thermostat (although I do not think that has made much difference) and replacement of the foam donut that connects the intake plenum to the heater motor... Darned thing sounds like a jet engine from outside now, no more engine related smells. An all round healthier system.
The mod though would give a little more control for the sake of the wife's comfort... |
7th Oct 2017 8:09am |
Sunshine Member Since: 18 Jul 2017 Location: Derbyshire Posts: 18 |
https://shop.landreiziger.nl/modificatie/m...uring.html
Has anyone ordered one of these as it does not seam that they deliver to uk or am I just been stupid |
3rd Mar 2018 5:21pm |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 |
I think they’re out of stock? I did PM Leeds/ Brendan about supplying them a while back but no reply so I assume he doesn’t
3rd Mar 2018 7:35pm |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1841 |
They definitely ship to the UK. I've ordered both their headlight loom and the heater control and they come pretty quickly via DHL. It's nice kit, well put together. The heater control I ordered about a month/6 weeks ago. It was showing as out of stock but I emailed Martin and he made one up and shipped it. Fitted it last weekend, and as Gareth says, a great mod. I was doing a bigger job - fitting a rebuilt heater box, with an allisport matrix - but I think if I'd just been fitting the Landreiziger kit it would only have been a couple of hours work tops. (If you're using Google Chrome, the translate button, top right of the URL bar, is pretty handy.) Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
3rd Mar 2018 7:46pm |
Thanks for the info I’ll have to have another look it just did not seam to have an option for uk and non of it was in English so I got a bit frustrated with it
Thanks again |
3rd Mar 2018 7:56pm |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 428 |
I fitted this mod a couple of years ago
Works really well and actually seems to increase the max output from the fan Its great to have the variable control for different fan output The only fault with mine is that the small lever that takes the original knob is very thin and mine snapped where the screw holds the knob on I soldered it back together and now its good and strong - may be worth beefing it up during the initial install |
3rd Mar 2018 9:47pm |
