![]() | Home > Td5 > TD5 Clutch/Gearbox issue |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
I have the screeching clutch issue in cold weather, but no problem selecting gears. It only makes a noise for the first clutch operation of the day (pulling off the driveway), then it's fine for the rest of the day. It makes the noise as the clutch bites though, not when the pedal is depressed. It's done it for years. Did yours make a noise before the gear selection issue? Or have the two things happened at the same time? 2005 Td5 | 90 Station Wagon | Tonga Green
harbydog Member Since: 25 Feb 2018 Location: Norfolk Posts: 6 ![]() ![]() ![]() |
Sounds like spigot bush. Which means opening it up to replace the £5 part, so you may as well do the clutch at the same time. If not that, clutch release bearing, but spigot bush is only normally noisy when cold. Either way, both normally adviseable to get done at the same time.
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 287 ![]() ![]() |
Thst's what I thought, Effie had t ohave a clutch at 88K, this one has done 110K, got away with replacing master/slave cylinders 'bout 88K but knew it was going to happen sometime Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
As you said, makes noise when it bites. Still have issue with selecting gears though, so perhaps something else other than spigot bush Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
srod Member Since: 20 Mar 2015 Location: Argyll Posts: 190 ![]() |
Assuming that its the spigot that is the problem - could it be that it there's enough friction between the dried out spigot and shaft that there's a small amount of torque being applied to the gearbox shaft, effectively spinning up the gearbox so your clutch pedal is doing nothing, thus preventing gear changes? Could you try giving it some revs when the clutch pedal is down to see if that helps free it off sooner? Or starting it in gear but with the clutch pedal down? |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 645 ![]() ![]() ![]() |
I had this problem of squeaking clutch for 4 years on Discovery 2. It was worse when cold, and it was slowly going from bad to very bad ant to gear changing problems. In terminal stadium when I was in low gear the car was slowly moving with pressed clutch.
All was because of the spigot bush. I have replaced the small cheap thing, and all is OK. Because of the labour with removing both gearboxes, I had also changed the clutch, refurbished both gearboxes and propshafts. Quite a lot of work for the small thing. ![]() ![]() ![]() |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6163 ![]() ![]() ![]() |
Mine squeeked/vibrated so much once today it lit the MIL light! obviously triggered the crank pos sensor or something!
And if I engage gear clutch pedal down and then start, everything is o.k. Guess I'll start saving for a clutch upgrade ![]() Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17721 ![]() ![]() ![]() |
This was a common problem with the Td5 circa 2002-4, apparently there was a batch of sintered spigot bushes used in production which hadn't been impregnated. My Disco had a new bush under warranty because of these exact symptoms.
Having tackled this job myself due to the annoying noise, and seeing that there seemed to be nothing wrong except a lack of grease, the job almost felt like a waste of time. Should have just put up with the squeal.
However hearing that things can end up getting seized up like this now makes me think it was good to get it sorted. Good luck with your fix! |
And of course Effie is a 2004 110 County ![]() Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
If it's lasted 14 years you've had your money's worth!
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 ![]() ![]() ![]() |
Mines a 2003 110 and mine has this squealing and sometimes a bad 1 to 1 vibration letting out the clutch when cold....
I hope i dont need to drop the driveline for this.....but sounds like i’ll have to....☹️ |
