Home > Puma (Tdci) > Battery Charging
Shuma
United Kingdom 2016 Defender 110 Puma 2.2 CSW Corris Grey
Battery Charging
110 not starting and alarm goes off when key is turned. So it seems that this is simply due to a flat battery.
To charge it the book says that the battery must be removed. Is this correct or can a charger simply be connected to the battery terminals without disconnecting everything?
I now realise that I will need a trickle charger if the vehicle is left for a few weeks. What works best and where to get one?
Post #689214 27th Feb 2018 10:19am
shayes
United Kingdom 1998 Defender 90 300 Tdi HT Coniston Green
Morning Chap,
I use an Optimate charger, that I used to use on my motorcycle. Simple connections and water proof if the Rover is left outside. I connected the battery connectors up and they hang out, just under the front of the battery box covers, but under the seat base. Plug in and forget.
Cheers,
Simon
Post #689216 27th Feb 2018 10:31am
ericvv
Most of us will use a Ctek charger. Do a search for Ctek on here and you will get three full pages of thread results. Below are a few of those threads which also highlights Martin’s adapters for easy connection. Never read a bad word about Ctek chargers.
Eric
http://www.defender2.net/forum/topic55204.html?highlight=ctek
http://www.defender2.net/forum/topic20342.html?highlight=ctek You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #689228 27th Feb 2018 10:56am
Balvaig
Whilst the handbook says disconnect the battery I think they are referring to the old fashioned rapid chargers used commercially.
I have used a CTEK charger on mine, wired direct to the connected battery, for 6 years without problem.
Post #689233 27th Feb 2018 11:02am
Shuma
Thanks guys much appreciated
Post #689242 27th Feb 2018 11:45am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
I only disconnected the flat battery when I used the reconditioning mode of the CTEK as this produces higher voltages than normal. Otherwise no need to disconnect. I have CTEK plugs connected to the batteries.
Post #689246 27th Feb 2018 12:00pm
MartinK
+1...
Made an "unbilical" with a battery health indictor, and I can plug the charger into here without removing the passenger seat Thumbs Up
 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #689251 27th Feb 2018 12:19pm
zsd-puma
the Ring branded smart chargers they sell in Halfords are good, they'll do trickle charging, as well as boost charging, battery reconditioning and testing etc. You can also use them with the battery connected.
The only reason the handbook says to disconnect the battery is that old style 'dumb' chargers would damage some of the vehicle electronics and alternator diodes if hooked up directly to the car. Land Rover don't know what sort of charger you're going to use, it could be a nice smart charger or it could be a rusty old thing you've had in the garage for the past 30 years. So they say disconnect to be on the safe side.
Post #689287 27th Feb 2018 2:41pm
TJH1985
CTEK here via the towing socket, backed into the garage at home and plugged in Thumbs Up
Post #689305 27th Feb 2018 3:36pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
I've got a little Maypole auto charger which was very cheap and has been going for years. Has two settings, fast charge which elevates battery voltage to 14.4V and keeps it there (alternator voltage) and a "trickle" setting which holds the battery about about 12.8V and can be left on indefinitely.
Really like the idea above of connecting for maintenance charging via the towing socket, I will look into that Thumbs Up ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #689479 28th Feb 2018 1:01am
Baz8046
United Kingdom 2002 Defender 90 Td5 HT Rutland Red
Ctek are very good and this socket will fit a Td5 dash if you don’t have electric windows.
 Defender Td5 Commercial 2002
Range Rover L322 TDV8 Westminster 2012
Discovery 4 SDV6 Landmark 2016
Post #689517 28th Feb 2018 10:14am
BobT
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
CTEK for me too via a permanently connected 12v socket in the rear of my 110 using the Comfort Indicator Cigarette Plug.
I run a 240v extension into the back of the 110 and I can still shut the door so it’s all contained inside, weatherproof and thief proof.
Post #689539 28th Feb 2018 11:47am
Shuma
Ctek
Well I bought the Ctek MXS 5.0 and started charging it today.
I also bought the comfort indicator panel like Baz8046.
I have electric windows so intend to fit the panel into the cubby box since its near the battery anyway.
Anyone else done this?
I dont have the correct tow electrics to charge from it.
Post #689795 28th Feb 2018 10:32pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
That´s a clever solution.
Excellent idea. Thumbs Up Thumbs Up Thumbs Up 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MT�s,
Recaro CS�s, anorak, wellingtons
Post #689857 1st Mar 2018 6:57am
