Home > Maintenance & Modifications > sqeeks and sqeals
Caterham
sqeeks and sqeals
I'm sure we'll have all experienced it.
I've always referred to it as a dry timing belt but I suspect it's the ancillary belt (the rubber one that does the a/c compressor among other things.
you know when you first start the engine you get a squeal etc. I've tended to pop the bonnet and give it all a liberal spray of WD40 but suspect there might be other / better advise out there?
Bow down
Post #688895 25th Feb 2018 9:06pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
I witnessed someone on a green laning day use baby powder on a squeeking belt. Seemed to work a charm and sent a lovely sweet smell into the air. Certainly got a funny look or two though!
Post #688908 25th Feb 2018 9:30pm
You're disguising a bearing failure on a pulley.....
Post #688915 25th Feb 2018 9:58pm
zsd-puma
A new belt from Land Rover is only about £25.
If they've been contaminated they can polish up on the backs and slip a bit. They're supposed to be good for 10 years, but it might even have stretched a bit.
Personally I'd order a new one, and whip the old one off, while it's off spin the pulleys by hand and check they're all quiet.
If you've been adding WD-40 on a regular basis it'll eventually not do the belt much good.
Post #688930 25th Feb 2018 10:27pm
WD 40 will make it slip more and more, it's supposed to do the exact opposite!
Change the belt over, and clean all the pulley mating faces problem should be gone.
I changed my belt over at 55k, really because it was easy and very cheap.
I occasionally had a squeak on start up, not any more.
Thumbs Up ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #688933 25th Feb 2018 10:51pm
zsd-puma
Exactly. Spraying WD-40 on it is just a diagnostic aid really. If you spray it on the belt and it goes quiet then you know the belt was slipping.
Post #689050 26th Feb 2018 4:58pm
Caterham
Shocked really?
Post #689073 26th Feb 2018 6:42pm
Caterham
Thumbs Up
aha. not looked yet but I'm guessing a simple job too? Nothing needs to be held in place like a timing belt right?
Thumbs Up
Post #689077 26th Feb 2018 6:45pm
No, pretty simple just the tensioner needs slackening off.
No need to remove fan or anything like that.
Obviously isolate the battery first. Thumbs Up ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #689079 26th Feb 2018 6:51pm
zsd-puma
There's a sticky in the TDCI section about it.
http://www.defender2.net/forum/topic47382.html
It's easier with the fan removed, but if you don't have the tool to remove the fan you can do it with it in situ.
Post #689085 26th Feb 2018 6:56pm
