Home > Td5 > Head gasket oil smear.
Gozy
United Kingdom 2004 Defender 90 Td5 SW Aintree Green
May have a problem ! Has anyone had an oil leak from the head gasket. Was checking the fuel regulator because had renewed it recently but noticed oil smear at the head gasket level right at the corner. Been checked it for about a week doesn’t seem to be coming from higher up any thoughts please.
Post #688718 25th Feb 2018 7:52am
rallysteve
Can almost guarantee it is the half moon shaped section on thr rocker cover gasket. Had the same myself. New genuine (Reinz) gasket and two small dabs of sealant either side of the half moon.
Post #688720 25th Feb 2018 8:03am
dorsetsmith
^^^^ Thumbs Up
Post #688726 25th Feb 2018 8:23am
Gozy
Thanks Steve so what you’re saying it’s the rocker gasket not the head gasket?
Post #688727 25th Feb 2018 8:33am
rallysteve
Yeah, the oil runs down the back of the head to the head/block join and runs down to near the FPR. Have had it myself and was convinced the rocker cover wasnt leaking but it was.
Post #688752 25th Feb 2018 10:54am
geobloke
Yup as above, 90% certain it will be that half moon part of the rocker cover seal at the back of the engine.
The other 10% is in fact oil leaking from between the head gasket and block/cylinder. This was, looking back at it, the first sign that my head was warped, very warped. Took a (as the engineer stated) darned good skim to get it flat again. The other symptom to look out for is the over pressurising of the coolant system. in the head picture you can see that i cleaned the head off, took it for a drive and the oil was coming from the gasket... clean off your engine and keep an eye on it...
Post #688900 25th Feb 2018 9:15pm
