Home > Technical > Diagnostics Advice |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello rmcgill
http://www.defender2.net/forum/topic10829.html or you could just take it to a LR Dealer (or good independent... ) to get a quick answer. I bought a Scangauge II on my first 'dashboard illumination', a non-issue as it turned out for me, but good to be able to see for yourself. Good Luck. SKIP https://www.defender2.net/forum/topic83242.html |
17th Feb 2018 4:18pm |
rmcgill Member Since: 28 Jan 2018 Location: West Yorkshire Posts: 7 |
Thanks for tips - will consider buying one. Is it easy to fit?
24th Feb 2018 8:05pm |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1308 |
Most are not a permanent fit - just plug into the OBD port
24th Feb 2018 11:11pm |
